- Thread starter
- #101
5W30I am ditching the 0W20. I do have a quesiton. I live in Phoenix. Would you go 5W30, 5W40 or 10W40 since we are rolling into summer?
I’d do 5w40 in Phoenix heat for sure.I am ditching the 0W20. I do have a quesiton. I live in Phoenix. Would you go 5W30, 5W40 or 10W40 since we are rolling into summer?
That's what I do, 5k intervals. OEM Filters, always. Switched over at 160k, now at 181 - all good. NC - pretty warm to hot here. Not Florida hot, but plenty hot enough. Lots of in-town commuting, but typically at least one medium to long-ish road trip a change. Disney. Colorado. That kind of stuff, hammer down rolling at highway speeds for full tanks (which thankfully, looking on the "bright side"20w50!!! Damn!
I’d run a 5w40 if Costco sold it. Their Kirkland brand 5w30 is under $25 for two 5 gallon jugs. Can’t beat that.
I chose to deviate due to my own training and experience with oil viscosity temperature dependence, and picking engine oil viscosity using (potentially out of date) enginerding charts. Because automotive engines tend to run over a range of rpm and not at static load, the "right" viscosity is somewhat variable. I am more concerned with maintaining oil film thickness than heat transfer. I have not personally seen the viscosity and temperature curves for the new classes of 0W20 oils, and so I have concerns with what film thickness they are able to provide when hot. If it becomes common place that folks who have done religious dealer maintenance on their 3UR engines are seeing 4-500k engine lives, then I will have been proven wrong. I simply don't see the depth of data to be comfortable with changing from the more traditional oil types.What convinced you to objectively deviate?
The reasons I've seen thus far for deviating: (1) assertion without justification that heavier oils will protect these engines better in heat (even though thinner oils cool more and have less heat-generating friction?), (2) heavier oil makes the engine quieter (I confess, that is appealing),
Feel free to call me old school, but I like high zinc/ZDDP engine oils, which WILL ruin a cat on an engine that burns oil. These tend to be the more diesel focused oils, as ZDDP is being eliminated from gasoline engine use due to the cat issue. But your point is well taken; hence using a 5W40 and not something like a 15W40. I have seen 15W40 shorten average (f150 V8) engine life from ~300k to ~250k as a result of excessive COLD START wear. The base oil in a 5W40 is still just a SAE 5 weight oil, with modifiers to bring the viscosity up at higher temperatures. A 0W30 or 0W40 might be an interesting choice. I simply have zero experience with these new classes of oil, and have not seen any published viscosity behavior with temperature.... and I have the aforementioned issue with a lack of extensive data.Anyone who chooses to heavy up, I don't expect you to crater your engine any time soon, nor do I think your catalytic convertors will plug up any time soon. I think you'll be fine. (Well, 40 weight makes me wince uncomfortably
I ran 0w40 in my truck that spec 5w30 for 4 years without any issues. Nothing wrong with running a 0w oil for quick flow.Not to hijack, but what about 0W-30? Great flow and protection at low temps/startup and a bit more viscous when things heat up. I base that perceived best of both worlds benefit on nothing fyi. Just a random thought.
forum.ih8mud.com
High performance German cars use 0w40 especially the BMW M series. 0 is chosen for the same reason (EPA), but smaller forced induced engines get more hot than naturally aspirated V8s, that’s why the 40 index is chosen.Not to hijack, but what about 0W-30? Great flow and protection at low temps/startup and a bit more viscous when things heat up. I base that perceived best of both worlds benefit on nothing fyi. Just a random thought.
Without too much technical know-how my experience with 5w30 has been very good. But I must say that few times we had freezing temp in Austin this year, the engine ticked more during cold start. But those days are very few for us here.I chose to deviate due to my own training and experience with oil viscosity temperature dependence, and picking engine oil viscosity using (potentially out of date) enginerding charts. Because automotive engines tend to run over a range of rpm and not at static load, the "right" viscosity is somewhat variable. I am more concerned with maintaining oil film thickness than heat transfer. I have not personally seen the viscosity and temperature curves for the new classes of 0W20 oils, and so I have concerns with what film thickness they are able to provide when hot. If it becomes common place that folks who have done religious dealer maintenance on their 3UR engines are seeing 4-500k engine lives, then I will have been proven wrong. I simply don't see the depth of data to be comfortable with changing from the more traditional oil types.
For those who are interested in learning more about oil viscosity, a reasonably well written article can be found here: Don't Ignore Viscosity Index When Selecting a Lubricant - https://www.machinerylubrication.com/Read/28956/lubricant-viscosity-index
A more automotive focused, but still layman level, article is here: https://ppp.purdue.edu/wp-content/uploads/2019/01/PPP-124.pdf ...and no, the irony is not lost on me that they recommend to follow the owners manual. That is typically your best course of action.... however as others have pointed out, Toyota changes what they recommend based on market. I am not sure this thread has really even answered why USDM is instructed to use 0W20, while ROW gets the more familiar temperature-oil type chart.
Agreed. Clicking on startup for a little bit. 90 seconds and it goes away.Without too much technical know-how my experience with 5w30 has been very good. But I must say that few times we had freezing temp in Austin this year, the engine ticked more during cold start. But those days are very few for us here.
The smoothness of 5w30 is very very noticeable.
The manual (US version) says that 5w30 is recommended while towing
Says heavier oils may be used under high load and high speed. So, by inference, it does.No it doesn't. I can almost guarantee that you will NOT find "5W30" in ANY US market literature associated with 5.7L LCs/LXs.
Taking the recommendation of layman here, versus validated guidance from the horses mouth in the manual, is a great way to do more harm than good. There's nothing to solve or make better when Toyota motors are some of the most reliable on the market.
@04UZJ100: Says heavier oils may be used under high load and high speed. So, by inference, it does.
From my LX manual
would not expect any adverse damage from running a 5 weight instead of 0.
What is debated? Proof was provided straight from Mr. T. There is no debate left.Yep. Not sure anyone is worried too much about going to 5. It's the 20 number that is being primarily debated.
