This is a good thread, lots of good info here.
With my new LX450 I'm moving to a slightly different and more configurable/manual setup than stock superglow system. With the old 1HD-T system, I would often experience very harsh cold starts in temps below -15C. During the winter my 1HD-T sees temps Avg ~-5C to -15C, and sometimes (for a couple weeks a year) into the mid -20C's and even -30Cs.
I've replaced all 6 plugs with HKT PT152's, which is an oem replacement 11/12V plug. I've maintained the main pre-glow (full power) large Toyota relay in the engine bay to supply the power from battery to glow plug bus bar. To trigger that, rather than use a "wilson switch", I'm going to use one of these adjustable pre/post glow systems from Australia: Bogaard DGT-2
Glow Plug Timers :: Features and Installation - Bogaard Distributors Pty Ltd
This will provide an adjustable pre-glow full voltage glow, and an after-glow to minimize rough idling/smoking when very cold.
I can turn up the pre-timer in the winter season, and in the summer I can simply turn the key to start (without waiting, which according to Bogaard will cancel the pre-glow as well as the after-glow.) If I want I could even hook a toggle switch to the Bogaard system to disable glow completely in the warm summers.
@KiwiDan80 , thanks for the info. What's a "long time" to damage the plug? If it's in the winter and I have pre-glow set to a full 30 seconds, is that too long? I've read elsewhere afterglow on these systems can be either half-voltage or a "pulsed" full voltage (on for 2 secs, off for 2 secs, repeat) which is the difference between the two Bogaard models. 60 degrees C for coolant temp probably takes a good few minutes in sub-zero temperatures I would think. Recalling how my truck would rough start/idle in cold, I believe it straightened itself out after approx 2-3 mins, of course depending on the ambient temps.
