The elbow is an elbow and grommet in one!
It's only the '63 to '67 defrost hose that is unobtainium. The later ones should be available from SOR. I recall them doing a sale on it earlier this year.I have both hoses and elbows off my 76 FJ40 I could send you to use as a pattern if you promise to return them and I know you would. I also have a air cleaner gasket that goes between the air cleaner and the bottom/top (don't remember if it goes on the top or bottom) of the air cleaner housing I could send. I do not have the gasket that goes around the lid. Send me a pm with your shipping address as I sold the shipping store and don't have your address readily available to me.
OK, we can let other folks post some pics. In any event, I'm deferring this project for now, as there are a few things cooking in the kitchen alreadyI would be surprised if the elbow is different unless the hole in the heater is different. The hose might be different just guessing though.
Sounds good. Just thought i would ask.OK, we can let other folks post some pics. In any event, I'm deferring this project for now, as there are a few things cooking in the kitchen already![]()
Maybe we can do something after the firewall boot project:
You can buy a rebuilt smog pump. It looks kinda crappy but I assume it works.how about the internals of the smog pump for 40's and 60's. you would be a god in cali if you can do that. I had to buy 3 used smog pumps before one worked. no rebuild kits
Early choke cables would be great!
I have a few of these fresh pull cables with the late model knob:Likewise, a lot of these dash cables tend to seize up and break. My heater pull knob/cable is completely shot. Seized in the sleeve and pulled out of the little metal "tip" in the engine bay. I believe the fresh-air pull knob is a similar design. I think they are all NLA from Toyota.
Shutterfly
Shutterfly
Does the cable look the same to you?
I can't speak to the length, as mine is still installed, but the connection looks the same. A metal anchor point at the base of the sleeve with a coil to connect the cables terminal end.
As you can see, the metal anchor has pulled off the sheath, probably because I pulled too hard trying to break the seized cable loose.
My 75's knobs don't have pictures, strictly writing:
Not sure when they switched from writing to images.
I have very few knob cables that I'd consider "working properly" in this truck. I might be able to salvage a few with cleaning and lubricating but some, like the warm pull assembly I pictured, are shot.
I've seen a lot of billet knobs, etc. for sale here and they're nice, but I really like the black plastic stock look - would love a replacement option aside from used.
