- Joined
- Apr 28, 2008
- Threads
- 61
- Messages
- 917
I think this is a good idea. I'll be following your progress. Good luck with it
I also think the steel platform attached to the spare tire lifting mechanism is a good idea (if you don't carry your spare there). My key concern is in finding cans that won't leak on their sides.Build a steel platform with vertical legs to bottom out against the floor when raised and attach to spare tire winch thing. Built in raising and lowering device. The steel platform will serve as protection also.
One of the issues people claim to have with the mod to raise the crossmember (and lowering the crank) is that the tire blocks the access to the crank. FJ/FZJ80 Spare tire lift (5" the easy way) I haven't done the mod, but I'm assuming the rod to turn the crank would fit between the cans.I think if you crawl under there you'll see that the spare tire crossmember is located far enough away from the body that it wastes a ton of space. From me mocking things up a week or so ago, I think it'll have to come out if you don't want the cans hanging below the bottom edge of the frame rails.
I have a swing-out spare and don't use the crank or underbody hanger. That's why I've thought of putting the Jerry cans in that space. But I agree with Blade 80LC that in theory the crank would fit between the cans.Totally forgot about that mod.. Just might work.
I was in the home Depot tonight and saw these. My eye-calipers said they are about the right size for that space. Too redneck? And maybe not these specifically, but army surplus aluminum boxes, or...?
I made this socket to be able to activate the winch effortlessly with my air ratchet and on board air. A regular 3/8 ratchet can also be used.
When fully up, nothing sticks out bellow the frame rails. Its a tight fit but it works!
