Turn Signal Wiring ?
Fargher Lake, Washington
I purchased a set of aftermarket turn signals for my FJ45 project.
The wire colors do not correspond to any published diagrams that I have found:
  • Red with blue stripe
  • Green with yellow stripe
  • Green
Any ideas on which is ground, running and turn?
if you remove the lense you should be able to see where the wire go.
I think the ground is established when you cinch the bolt on the underside of the fender. Perhaps yours is different though. Does your harness have 3 female bullets? I scuffed the underside up to bare metal just around the bolt on mine.
What year 45?
