- Thread starter
- #61
8 am work for you too Braden? Figure if you and Mo can meet by 8:00 from the Orange Curtain then us S.D. guys can do the same. What is it a little over an hour for us in SD to the meeting spot?
Nope.Bluto said:is this run closed?
is this run closed?
Costco would be going the wrong way for me to meet you guys there.
Are you going out through Ramona/Santa Ysabel/Julian? Since we're not going to Borrego Springs, that is the way I'm heading.
The 76 is most likey the way the OC guys will be coming in anyway.You are meeting at Costco. I was using Santa Ysabel as a reference point. Most of us will be passing through there.Bluetribal said:Whoah, Whoah Whoah, you guys are confused on where we are meeting.
Santa Ysabel / Julian / 78 & Borrego Springs Rd. (about 41 mins)Bluetribal said:So our two options are stay on the 78
Santa Ysabel / S-2 / 78 & Borrego Springs Rd. (about 52 mins)Bluetribal said:or go left at Santa Ysabel (79) to S-2 and back to the 78 to avoid the curves.
Did you check out the links/maps?
HTH
8:00am is fine with me.
Moe, do you want to meet up and caravan?
Sounds like the weather will be awesome.
Did do some killer wheeling though with the trails all to myself. I just thought of something, if we don't take S22 down into Borrego springs proper are there any gas stops to top off along S2 somewhat near our meeting place? If not we will have to go through Borrego Springs to top off and head down Borrego Springs Rd. The last time through there I took S3 down out of town and it was not a bad drive, just a few tight spots right as it drops down onto the 78.
To be totally accurate we are meeting at 78 and Borrego Springs Rd at 8 am on Sat Nov. 24th. Right?
HA! I remeber that.Slomo said:I only mention this becuase last time I went out to meet up with Smitty and crew I went on the Sat before the run and found myself solo in Borrego.![]()
This is right down the road from me. So are you all meeting there around 6-6:15, fueling up and heading out? This is my first official run, anything that I should bring that is a necessity?Yeah, good point Dan. How about the Costco Gas station by Qualcomm? My G.F. & I both have cards if any of you aren't members. And at 6:00-6:15.
You, your rig, something to keep you hydrated, and a turkey sandwich.Giulitto said:This is my first official run, anything that I should bring that is a necessity?
