Ah, and after all that, of course it didn't line up. Nothing comes easy, does it? So, I just need to find some 2 3/4 ID flex tube/duct and mate the two up - then I'll be in business.
I will say this is one area that the TG kit made me want to pull my hair out. I modified the air cleaner lid as pictured (correct length), and yet the supplied rubber hose is too short and it's a really tight, funky angle too.
TG, if you are reading this: just include a long uncut piece of tubing and let the end user cut it to size - otherwise the margin for error is too small. So, now I hunt for 2 3/4 flexible tubing...
Are you sure you've got the Cobra fitting on the right way? I think you want to put the open end in this picture on your air cleaner--it sure looks like it would about fit with just a 90 degree elbow then.
I don't know what the Turboglide instructions or other parts look like, but I'd try that. You can also buy heavy rubber pieces to do the same stuff (which will have a little, itty bitty bit of wiggle to them) at a filter supply house.
Dan
Thanks for slapping the back of my head. I should be good to go tonight. I can almost
