- Joined
- Aug 5, 2013
- Threads
- 11
- Messages
- 183
Hi guys. I've been reading here for a while but only just signed up to see if anyone here can answer a few questions for me. I bought a 97 land cruiser with a HKS T04Z turbo a while back. Ive been doing a bunch of repairs and PM on the brakes and body and am just getting to the engine. I've already changed all the rotors and brake lines and rebuilt all the calipers. I've also removed the roof rack and cut out the rust on the roof and welded in new patches. It has the Emanage ultimate piggyback ECU and i have a few codes that the Toyota ECU is showing that I'd like to get rid of. One code is P0110 AIT sensor failure which is expected since the MAF has been removed and a MAP sensor used instead. I would like to install a stand alone IAT but cant find any info on what the values are on the built in one so I can find something that will match. I found a fast reacting IAT for my RX7 by matching up the values with the old slow reacting one and am hoping to do the same here. Can any of you point me in the right direction to find specs on it? I know I'll have to retune the emanage when I get a sensor working but think it will give me a little more low end power. I also have codes for both knock sensors but will track down whats going on with the wiring later in the week when I have time. They might have disconnected them because of getting knock readings when they were running the thing on 22lbs of boost using race gas. I'm running 16lbs now and plan on leaving it at that.
Sorry for the long post but I'll get some pictures up tomorrow so you can at least get a look at my headahce. Its been taken in the complete opposite direction than everyones rig on here its a very fast grocery getter. I already have a hilux surf with 35s and am half way through my V8 conversion on that so don't have any plans right now to offroad the Cruiser.
