Thinking about picking up their snatch strap...only 35 bucs.
I purchased this by mistake (it's m10x1.25 arbor vs 5/8" like my angle grinders) and Amazon chose to refund my money and not take the item back. Guess it was cheaper than shipping.
Free to whomever can use it.
Amazon.com: Forney 72780 Wire Cup Brush, Crimped with M10-by-1.25 Arbor, 2-3/4-Inch-by-.014-Inch: Home Improvement
Can always use one of these. Sure.
You be at M&G?
?No...be in London for work. It's yours though and can get it to another way. Assuming you have something with this arbor size? British angle grinder?
I would very much like to be in London for work......instead I'm going to Hanoi in a few weeks!
Hanoi seems like a cool place if you're in to traveling. Much longer flight though!
First time for me. Been to London 4 times since 1985 & spent a total of 4 months there. My favorite city hands down & im not a city guy! You go there often?
Dayum! Enjoy!First time actually but will likely be visiting at least a few times each year now. Also Poland, South Africa, China, and potentially Malasia and Pakastan.
Picked these up today .... Because you just can't have enough snap ring pliers. I love this concept ... flip a switch and they alternate between expansion and contraction.
You'll have to report how you like them after a few uses. I did not like the Craftsman version of those I had a while back.
Well, I thought I was going to get to use them tonight. I pulled the drive flanges off the 80 to snug up the wheel bearings but forgot the retaining ring for the axle shaft had speared ends and not lug holes. Another time.
Even with snap rings that have lug holes, I found that those pliers didn't have lugs strong enough and the lugs would snap off. In a pinch take a pair of the spare ends that come with those pliers and cut the little tips off of them. Should give you a large enough flat surface to get that snap ring off.
Snap-ring pliers with a flat bit like this are far and away the best I've found for the axle shaft retainer ring, among a ton of other spear type snap-rings found on Toyotas:
