replaced all 4 rear brake cylinders on my 77 fj40, i can't bleed drivers side . pass side bleeds normally drivers side i can hardly get a trickle after pumping em up and opening bleeder any thoughts?
If your short handed these may help. I've never tried them but you can find reviews on line.
http://www.russellperformance.com/mc/speed/import.shtml
Don't you guys have any friends or family to help you bleed brakes?
The two person method always works if it is done properly without letting air back into the system.
That's great you had success bleeding your brakes, but posting in 7 or more different threads with the same text is a little over kill. A lot of the post you pulled up are 10 yrs old or older, and none are from this decade. I'm pretty sure most of those folks have resolved their issues. Its surprising you couldn't find something more recent because this is a common subject.I have just spent a month of Sundays on this exact issue; this is how I finally fixed it.
You need a 1 pint ball jar with two holes through the lid into which go 1/4 inch clear flex
lines about 18 inches each run to the bottom of the jar
Starting rear driver brake single bleeder, connect 1/4 inch tube and crack bleeder and
start engine. Then sieze that pedal with both hands and drive it to the floor and then quickly pull
it towards you as fast and hard as you can repeatedly watching as the res quickly empties
fill res asnd repeat until the pint jar is full. Repeat for rear passenger. For the fronts starting
with passenger connect both hoses and crack both bleeders then really get all your frustration
out on that pedal, all the pain and frustration these dam brakes have given you. When the jar
is full close the bleeders and move on to the drivers front and repeat.
This is will work, takes 15 minutes costs a couple bucks
Good luck all
I posted it in all the threads I have been reading for the last year trying to figure this out none of which have any resolutions or success posted. I figured if I hit the ones that show up at the top of the list so when others go looking they will find it. Sorry if you had to read it so many times.That's great you had success bleeding your brakes, but posting in 7 or more different threads with the same text is a little over kill. A lot of the post you pulled up are 10 yrs old or older, and none are from this decade. I'm pretty sure most of those folks have resolved their issues. Its surprising you couldn't find something more recent because this is a common subject.
