TRANY GURU please
rainbow city AL.
Website
www.frankies4x4.com
94 80 series rocking it hard in a mud hole lost all forward gears and have a strong reverse ,no burnt smell fluid is good did not over heat just a hell beating a couple R TO D drops.
About to do the recovery and would like to here what the cause may be when i get back hope some one has has the same problem so i can skip wasting time looking for the problem or go internal for a reman.
thanks,,,
Frankie...
Frankie,
It might be possible that you broke the linkage. It is a real PITA to get to on top.
You might actually get lucky and it might just magically start working now that it has cooled down.
Good luck.
Are the dashboard tally lamps lit correctly? They are run from the neutral start switch which is located on the side of the tranny. On later model trannies they recieve this gear select signal as they are electronically controlled. If the NSS was damaged, the tranny wouldn't know what gear was selected.
If all electric looks good and works correctly, drop the tranny pan and check the intake filter screen.
Has the transmission fluid been replaced regularly on this rig?
Do you have a 442? I think I read in the FSM that although forward gears are controlled by the electric solenoids, reverse isn't so you could have an electrical fault. FSM RM315E details how to test quite a lot of simple 442 tranny stuff, enough to eliminate electrical gremlins.
Hi Frankie,
Any feedback for us??
Wish it would have been something easy but it wasnt.
Broken steels and sprags and all kinds of goodies i just put a used one in there have found them to be plentyfull at the bone yards and cheap for a shop to buy.
I beat this thing hard and have no hard fealings for the failure:)
Frankie...
hole crap!!! batman.:eek:
There is a reason why they named the Forum IH8mud.com.
Stay out of the MUD.:doh:
Whoa, and that's the heavy duty transmission compared to the 95+ versions...
thanks,,,
Frankie...
I'll say this. I would love to see how you tore up your tranny. I had a '94 for twelve years, and I never even had a hiccup in any of the mudholes which I frequented.
He is in Alabama. He has no choice. As a driver in Alabama, you can select from the three following surfaces:
1. pavement
2. mud
3. pond.
That's it.
:lol::doh:
1. pavement
2. mud
3. pond.
That's it.
That's true everywhere except N.E. AL.
I am at the foothills of the applacaian mtn's and have plenty of rocks to play on as well..
Same here when I'm at home in the J'ville area.
ooh, pick me! I love to play in the mud...
You find a bone yard close to you with LC parts?
Oh yeah, all you bama folks, ya'll coming to the crawl in 12 days? There's rocks there and yeah, it's Alabama!
