Automatic Gearbox breakdown...Help!!
Asturias(Spain)-London(England)
Website
www.sybaris-expediciones.com
Hello.
I have an HDJ 81 diesel '91 RHD (Japanese import) with automatic gearbox (the old one, without overdrive).
Last thursday, I got stuck in a lake that seemed to be dry, but it had half a meter of mud.
I was pulled by another 80 and, after ten times, I went out from that (before, trying to get out, I changed between D and R quite fast for ten times).
The fact is, after that, I run for a mile perfectly, but, suddenly, the gearbox started to slipper when going uphill, (like a manual when the clutch is burned).
I stopped and try again, but the car didn't move. I tried in low range, 1, 2, 3, but nothing. I put the reverse and went back to a flat part of the way. In the flat part, the car moved a little bit but almost nothing. In reverse, it goes perfect, even uphill.
I took it to the toyota official service but they don't know what it could be (I'm in Spain now, and here they don't know a lot about automatic gearboxes). They said it could be a small thing or maybe have to replace the whole gearbox.
Any ideas? I'm so desperate, cause a friend of mine broke down his gearbox in his HDJ 100 and had to pay 4000 euros about 6000 dollars for a new one in the toyot dealer...I'd rather buy another car!! In my friend's case, the car didn't go forward or backward, that's why I hope in my case I don't have to get a new gearbox.
PS: I had changed the gearbox oil one month ago, and the A/T oil temp light didn't came in.
I forgot to tell you that, when the gearbox started to fail, I pressed the red button that is in it several times.
I don't know what that button is for!!, it has something written in japanese near it.
I a have the user's manual translated into english, but it doesn't says anything about that particular buttton.
I know I shouldn't have pressed it without knowing what it was for, but I was quite scared that the gearbox was hot and thought it was to press in case the gearbox is hot.
Could that be part of the problem?
The red button only allows you to release the shifter from park with the engine off. You caused no harm by doing that.
The early automatic is fairly robust. So don't start to panic yet.
First thing is to try a fluid change.
If you get stuck for parts drop me a line. But don't ask for a used tranny, that one is hard to find and well liked.
Thank you Japan4x4, I'll ask you for parts if I needed.
The fluid had been changed a month ago, and it worked fine all this time, that's why I can't understand how this could happen.
Everyone I know that broke the gearbox, it was because of waiting so much to change the gearbox oil.
Anyone else's got a clue about what had really happened with my gearbox?
Thanks a lot.
Ok, thank you Japan 4x4.
I'll ask them if they will do that.
If anyone else have some clues about it, please post them.
Thank you.
I'm worried that you keep calling it a gear box. You didn't by chance put gear oil in it did you? You used Dextron ATF right? ANy signs of fluid leaks near where you were stuck? maybe you broke a tranny cooler line?
I'm sure they put the right oil, they changed in a toyota dealer in London.
I haven't seen any fluid, but there were lots of mud. I looked after, on dry cement, and didn't see any fluid leak.
Sorry for my english, but I don't know what a tranny is. I tried to tranlate it by google but I couldn't.
Could you explain it in another words?
Thank you.
Have you checked the fluid level since the incident? If not do so. How many miles are on the Cruiser? The best and universal description is Manual Transmission for a old style gearbox and Automatic Transmission for the kind without a clutch.
My Cruiser has 245,000 miles on the original transmission that's why I was asking about milage. The Auto's should go to 300k miles.
I can't check the oil level, the car is now in the Toyota garage, but I'd like you to give me some clues, cause here they don't know lots about automatic transmisions, and, when I took the car there, they were puzzled, they didn't understand why the car could go reverse, but not forward.
My cruiser is quite new, it's got only 90000 miles. I'm quite sure it hasn't been clocked cause I have the service records.
With the oil changed so short ago and so small mileage, the conclusion is I'm not being very lucky...and the worst part, is, I only drove it for 500 miles since I bought it two months ago!
I must confess....the other reason I come to the forum with the car already in the Toyota garage, is that I don't want them to trick me. It wouldn't be the first time it happens here, and I wouldn't be surprised if they wanted me to buy the whole transmission even if it could be repaired.
Disclaimer: I am not a transmission person; nor familiar with your transmission so just take this for what its worth. The first thing I would do is pull the dipstick and smell it. If the oil smells burnt then my guess would be a burned clutch pack, most likely the forward clutch. Since you have reverse it would seem that the torque converter and pump are good and making pressure. By the cruiser being able to barely creep in forward either the clutches are not getting enough oil pressure to apply them, or they are burned up and just slipping. There could be other causes for losing pressure such as a cracked valve body etc. If they drop the pan there may be clutch material in the oil or pan.
In my youth I was stuck in snow and banged the transmission back and forth which resulted in replacing the transmission because I burned out the clutches.
Good luck to you.
Bill
Thank you Bill.
So there is a clutch for forward and another one for reverse?
That might be the point!!
If it can go forward..but very very slowly and slippering, and goes reverse perfectly...that must be the main bet, that the forward clutch is burned.
Am I right?
I don’t want to mislead you so here are a couple of diagrams. Think of the diagram (picture 1) as a generic automatic transmission. Since you said you are familiar with manual transmissions, I don’t know if you ever worked on large trucks or not. Their manual clutches are double disk or triple disk. In other words there is the flywheel, a clutch plate; then a steel disk; then another clutch plate and perhaps another set. This is very crudely an analogy to what is in an automatic transmission. In an automatic the terms are plate, disk, plate, disk, etc. I call these sets a clutch pack, but that might be the wrong term, just what we always called them. Example picture two.
Unfortunately, to get to any of this stuff requires the transmission to be pulled and taken apart. It sounds like in your situation it would be cost prohibitive to have this done if someone could be found competent enough to do it. If this is found to be true in your case, a replacement transmission is probably your only recourse.
Maybe a transmission person will see your thread and come up with something more hopeful.
Bill
Thank you Bill.
That's more or less what they told me in the Toyota service. They said I won't find anyone that's going to open and fix the transmission and charge a reasonable price.
But they gave me a hope: the mechanic said that he's quite sure that the transmission is ok and what's wrong is what we call in spanish "volante de inercia", that could be translated more or less as inertia wheel. I'm not very good at mechanical terms so I can't explain you very good about what is it, maybe if someone else that speak spanish could help me with that.
Anyway, they told me that can be replaced for a new one for about 800 € (1040 dollars). That's a lot of money but nothing compared with the 3000 € that cost a new transmission.
Volante de inercia sounds like torque converter to me...........
I have had this exact problem in chevy autos, and it required a rebuild or replacement.......
Quote: Canonero: Sorry for my english, but I don't know what a tranny is. I tried to tranlate it by google but I couldn't.
Can't help but chuckle about the results that search must have produced. :o
Back to tech: I would go with the torque converter too.
After 15 days waiting, they couldn't find an easy solution: I got a call from Toyota today and they said the transmision has to be taken to an automatic transmision specialist and has to be completely rebuilt.
Translation: 800 € ( 1000 $) from Toyota plus 2000 € (2600 $ from the specialist). It'll be warrantied for a year.
Second option: new transmision by Toyota: 5000 € (6500 $) Are they joking?
Third option: salvage parts: about 750 € for a transmision in England, plus the shipping to Spain. Cheapest way, but no warranty, and I don't know the state of the transmision, maybe it's got 400000 miles.
They told me two interesting things:
1) One of the reasons because the transmision broke is that mud entered into the "ventilation lines" of the transmision. I don't have a clue of what that lines are, but that's what they said and the transmision expert said it's very common in four wheel drive cars to break down the transmision when crossing rivers or getting into deep mud because it enters in this tubes. Solution: take them up or even connect them to the snorkel (it sound very weird to me, but they said It can be done). Cost: about 60 €.
2) The non-overdrive transmision, previous 93 (at least in HDJ), is got a big weakness: the radiator is shared with the engine and it doesn't cool the transmision as it should. Solution: to fit in an independient oil radiator for the transmsision similar to the one with overdrive. Cost: about 150 €.
What do you thinkj?............I'm quite desperate, don't know what to think.
