First gear is so deep it overcomes the taller final drive. Teckis has written about this elsewhere. Plus if you want to regear for larger tires 3.9s are a great option, and readily available with low miles from the earlier trucks. And, factory toyota gears which are IMO superior to anything aftermarket.It’s kind of dumb if you ask me to kill the NA throttle response experience by hunting down 3 gears when you actually need the motor.
For what even, dont the 2015 and 2016 get the same MPG? Perhaps some benefit in towing or acceleration. Someone post the numbers I’m too lazy right now.
But still, IMO not worth it. I know @bloc has told me before he thinks it would be nice for gear advantage on 34”s+. But bloc, didn’t you just post about the final drive ratio also being lower? I need to educate myself on the mechanics of all this. What are the technical pros ?
My gut is the move toward the 8spd was all marketing pressure. Americans “get” higher numbers being “better.” Plus it may have an emissions benefit, though that’s just a guess.
