You dont have an Oreilley near you do you? usually theres one in your town thats bigger than the other that serves as the hub for the smaller stores. If you find that shop theyll usually have a machine to resurface rotors and flywheels. Oreilley did my 22re flywheel some years back.
- First weird thing was gear oil pouring out of the TC when the rear drive shaft was removed. I don't remember that happening before.
Depending on how much is "pouring" its either a rear output shaft seal or theres no sealant on the splines of the rear output shaft.
As far as the Tcase removal and rebuild, everything you need is in these two videos. Its pretty dang easy to do, even up under the truck. Your arms just get tired from holding the heavy parts after a while.
agreed. if thats the case it wont leak too too much but it will still leak. The flange on the driveshaft actually makes a pretty damn tight seal onto the output of the t case though so it wont really dripI had oil coming down the splines past the hub seal before I did my rebuild. If you don’t use gear oil safe rtv on the splines then oil will migrate down the output shaft splines.
I was taught to use lithium on the input shaft. Anybody got a better idea?As others said.. out is easy. Putting that puppy back in might take some lube ...
If you do literally everything solo like me... you have to get creative.
My experience is of stabbing 1600cc VW motors in. This has a lot in common but the married trans is at least twice as heavy and asymmetrical. On my side is my 18 yr old son helping. Against me is we are working on a sloped driveway. I am so grateful that we have a concrete slap under us. It might be snowing, but that beats driving rain.As others said.. out is easy. Putting that puppy back in might take some lube ...
I heard a machinist say the cracks were fine, Most semi-trucks just resurface and deal with it -Quote from machinist I usedView attachment 2876259
Now here is my dilemma. Nobody in Moab resurfaces flywheels. Second, look at those cracks!
Yep, it too late. I already seated the pilot bearing and I wish I'd had this foresight. Thanks anyhow. Maybe this was that feeling I got when the rest went so well? What I can do is lube it. ,, And hope for the best. The engine aligned slightly down, and eyeball the alignment with the shaft,, What you don't know is that we are doing this on a sloped driveway. This is why we had success on the year down.It’s too late now (sorry to break the news) but it’s important to test fit the pilot bearing onto the input shaft tip to make sure it’s a nice fit and not too tight or too loose.
If the fit is a bit tight, you’ll struggle trying to mate the transmission up all the way as it hangs up on the tip.
When inserting the transmission assembly into the flywheel pilot bearing, it’s never a perfectly parallel slide right in affair. Almost always the tranny will hang up and won’t budge for the last 1/2” as the input shaft isn’t perfectly aligned and you’re not rolling the transmission perfectly parallel at the right angle.
Not knowing for sure if the input shaft can slide ok into the pilot bearing beforehand usually will turn a cuss free day into a swearfest — but it’s been done before. Lots of times by others.
That's "Golden advice". I nearly forgot.Use some ratchet straps to help pull. Also you can use some longer bolts and “carefully” use the bolts to snug it up.
6" inch guide bolts? I may not have the in the magic bolt bucketGuide bolts in the two lower BH holes will help a lot, and only use the two lower holes.
