I put the 40 into 4wd this weekend and had an intermittent growling vibration issue. I took it out on the road in 4wd high and it would growl and then go away depending on load. My first guess was u-joints. Yesterday I removed the front driveline to check the u-joints and to feel the transfer case and front axle without the driveline in place. The u-joints had no play in them. The front output flange has some play in it, how much is too much? The flange at the front axle has very little play and feels really smooth with little or no perceivable backlash. I change the gear oil while I was at it. My concern is the front of the transfer case. How difficult is it to change the front bearing on the t-case? I have the bypass hose from the tranny to transfer and have no leaks to speak of.
job is that?
