Tranny help (1 Viewer)
Savannah,Ga
94 LC when put into D it moves forward at 2000rpms same as reverse. I am going to drain the fluid and replace. I also adjusted the cable. I will keep posted if that helps.
...via IH8MUD app
Savannah,Ga
My tranny oil and not much came out. Half quart maybe. No wonder I am slipping. You never know how well previous owner took care of vehicle. Fml!
...via IH8MUD app
Savannah,Ga
So was it reading low on the dipstick?
Yes it read really low. And I figured I get in there and do it. I also purchased Lucas tranny fix it cleaner. Then I will do another tranny change with my engine oil change(5000k) miles to go.
Wow. Is that water mixed with the trans fluid?
I think so. Or it might be coolant? Reason I say coolant is because my coolant looked like that because they mixed green with red. Any thoughts?
Savannah,Ga
My radiator is in good condition, when I filled her up after flushing 5 times with water and filled her up with green and let her just run in idle until regular operating temps and nothing bad happened... But I am no expert.
AZ
If I were you and I'm not, I'd skip any trans. additives and just stick with a good ATF like Mobil 1 Dex II/III, keep it simple ya know.
Savannah,Ga
Oh yeah I am sticking to that for sure! I am going to put 6 quarts in and drive it around the block. drive it in my drive way reverse and forward for a total time 20-30 minutes, drain it. pull the oil cover, clean it, replace the filter and refill.
