- Thread starter
- #21
60"is your rack the 60" or 48" version?
What craftsman Toolbox is that? I want.I looked at the go aero hard...but at like $500 it was a bit much and the reviews weren’t stellar. I settled on this one from Amazon...it comes with metal bits to carry 4 bicycles at a time and is very very large. I took the bike parts off but they go back on easily enough.
i wanted it closer to the vehicle and higher up so I cut some of the tongue off, drilled a new hole for the hitch pin, and added a riser...it appears to improve my potential departure angle and allows for a recovery point or the ability to pull my little travel trailer while the basket is attached. I also shortened the riser and drilled a new pin hole for it too.
it hasn’t arrived, but I’ve had such a hard time installing the hitch pin on the 200 series that I purchased the hitch pin I’ll link to as well. I’m hoping it’ll make securing the pin easier.
also, one of the downsides to using these baskets or putting the baskets on a riser is that you lose the ability to get full access to your tailgate...I sort of solved this by installing a 48” toolbox...I drilled holes through the bottom of it and bolted it to the rear tie downs (after removing them). This allows me to keep full use of my 3rd row (including recline) and also keeps all my tools, recovery gear, and a spare alternator stowed in a safe manner.
between the toolbox and 3rd row I can fit a spare cv shaft, starter, axe, and a few soft items (spare clothes.
ive got a ton of stuff in there.
im thinking I may drill some lash points near where you see the waffleboards on the basket, thereby allowing my to strap an easy up between the basket and the truck. I think I’d still have just enough room to scoot in between the easy up and the rear of the truck in the event I need to get into the hatch on a road trip. The waffleboards were just set there to see if they’d fit and because I was thinking if I lashed them there somehow, I’d have an even larger platform.
Tow Tuff TTF-2762ACBR 2-in-1 Aluminum Cargo Carrier with Bike Rack Amazon product ASIN B00PXNC7K0
Master Lock Hitch Pin, Stainless Steel Barrel Head Hitch Pin, Fits 5/8 in. Receivers, 1465DAT Amazon product ASIN B000COX0MY
If memory serves, it was this one.What craftsman Toolbox is that? I want.
I’ve been barking up this same tree and just doing research. I found Letsgoaero.com had some cool fiberglass hitch enclosures but they are much more expensive than I could justify. Then I saw they have a wide (6’) cargo tray, and what appears to be a pretty inexpensive water resistant expandable bag for that tray.
I was kind of thinking of fabricating a platform for this bag off of an unused aluminum motorcycle carrier I have
Are you welding up your own swingarm @TeCKis300 ? And you have probably seen this while researching which I liked the idea of. Just have to know that your camp spot couldn’t require significant drop offs along the trail or you’d be dragging anything something terrible. I was thinking dropping the hitch at a campsite then going further might work.
It wobbled a bit much for my taste to I added a brace. Seems pretty solid now.New 35’s so the tire wouldn’t fit under the vehicle anymore. I bolted a (modified) trailer spare tire holder to the hitch carrier…then bolted a wheel spacer to the spare tire holder.
BUNKER INDUST Spare Tire Carrier - 120LBS Weight Capacity for Side Mount of Trailer Tongue,Fits Most 4 & 5 Lugs Wheels,Hold 3.94″, 4″, 4.25″ and 4.72″ Bolt Patterns https://www.amazon.com/dp/B096RPVHKJ?tag=ihco-20
I actually went ahead and moved the brace to the swing arm itself…so now I can just pull the pin and swing the whole apparatus rather than having to pull two pins to open it to get to the back hatch.Wow. Looks great, but like a bit of a process to access the back hatch. Do you have plans to replace this with a traditional swing out tire carrier from ARB or is it not as bad as i am imagining?
Got my new weather proof cases for the Pakmule! Cases and carrier all made in TEXAS!
I like the Pakmule products - expensive but very well made in the USA.
Been thinking about combining the new Scout model with a Wilco swing out arm and an extender/riser between to keep it high and tight to the tailgate. Should be more than enough space to carry all the camp galley supplies plus some other miscellaneous materials. That way I can maintain the roof and second/third row without having to go rooftop tent or drawers, which are great but less modular/removable for my rig which is still a daily driver.
Are those the 35 10.50's? if so how do you like them? Thinking about trying those on my 8.5" wide Icons.New 35’s so the tire wouldn’t fit under the vehicle anymore. I bolted a (modified) trailer spare tire holder to the hitch carrier…then bolted a wheel spacer to the spare tire holder.
Yes. I think they look and ride great. Wish I’d gone w a size that fits in spare well though..I was hoping due to my arb rear bumper I’d be able to fit it. But it’s 34.75” actual height on unweighted. No way it’ll fit.Are those the 35 10.50's? if so how do you like them? Thinking about trying those on my 8.5" wide Icons.
What brand are the coolers on your carrier rack?Got my new weather proof cases for the Pakmule! Cases and carrier all made in TEXAS!
How do these handle weather extremes with the exposure on the carrier?Oops, I guess that’s an important part of the post.
33" Large Case #2152
We've gone full beast mode. This 33" tank of a case holds all your stuff and more. Off road style wheels, patented latches and much more. Come see this hard case.condition1.com
I have one of their rifle cases too and love them.
These are military grade cases that are sealed from outside elements (rain, snow, dust). They are not however insulated, so if it’s cold/hot outside it’s the same inside the case.How do these handle weather extremes with the exposure on the carrier?
