trail lights
CANADA
somebody on this forum has installed lights underneath their rig, ie differential lights/ trail lights, wondering who it is as they posted on this forum recently but i cant find there thread. i want to install somthing similar
thanks
matt
I have them on mine. What do you want to know?
want sort of basic setup, pics, model of lights etc...including switches
go to harbor frieght or the like and get some 'work' lights. They have fluted lenses and a wide angle beam.
Help you Help Me
Here is the Setup I have routed...Just waiting for the dual battery setup b/c I just have way too much s*** wired to the one Bat. I'm running currently.
I'm not sure on the switch part of it but I think it should be cool. PLEASE correct my wiring or an improved route if you would like. The electrical stuff is not my strongest point.
It should be rather simple to understand and hope the chart is sufficient.
I used 14gauge wire all around.
Sam
I wouldn't run that kind of amperage through a switch. 55 watt lights should be about 4.6 amps a piece, and with 6 of them you're looking at 27.6. Not sure why you have two on one slider and only one on the other, so if you even that out and decide to put 7 on you're over 30amps.
I would run little wires to the switch, and use the switch to activate two 20 or 30 amp relays.
You could find lights less than 55 watts I suppose, there are some small fogs out there that are like 35watts. Don't know how much spread you'll get on the beams though compared to a work light.
Just food for thought...
You will definatley want to use a relay. If you want to switch them all at the same time use one, if you want different banks use multiple.
I'm not sure why you show two 30amp fuses in parallel, unless you wanted to fuse at 60 amps? Even then you're asking for trouble, use one fuse that is sized correctly for what you require.
Here is a diagram showing the general idea. If you want another bank, like I noted above, just add another relay with the next set of lights.
Using a terminal block as shown is a very clean way to land wires, allow easy maintenance and make it look professional. Try to use a block that covers your connections sufficiently for safety and protection for your equipment. I prefer to run the ground wires back to where you pick up the power to prevent unequal grounding. It probably isn't significant with lights, but it is good practice in general.
In my drawing lines that cross with a circle around them connect, no circle no connection. Pardon my sloppy drafting, I generated this using a drafting program I haven't used before. Don't mind that misplaced + symbol on one of the lights, woops.
pic?, anything to show the lights underneath and where u mounted them
Yep, definitely run relays for the lights :)
For my rig, I have a relay for each panel of lights stored in a box on the roof:
The relays have their own fuse block which gets juice from a nice fat 2Ga. welding wire :cool:
And each relay is triggered by smaller switched wires that carry low current, so there's no chance of melting a switch:
Only have roof lights at the moment, but I plan on rock lights after a decent lift :cool:
I'm just running cheap Wal Mart $14/pair lights. That way I don't cry when they break from stones. I run a hazard switch down next to the rear heat switch to turn them all on. I mounted them using the running board bolts in some spots. On top of the spare tire carrier in the rear and in the front inner fender on the frame in front. I also have two small ones facing down in the front near the tow hooks and one face backwards towards the axle. Everything is pointed down so as to not blind the spotter. I'll see if I can get a photo some evening.
Great Info...have a pair of relay I picked up at the shop, but don't know what goes to where. Will try and post pics of the relays in hopes of some help...Similar to GIN, my lights are $14 cheapos at about 30 watts a piece, worklamps with a spread lens on them...
I have Two on my DS B/c that's the side I can see out of best when driving. No need for a light where I can't see it.
Snake - way to go - a clean and well executed set up. Kudos :beer:
You're spotter might be able to see it. Also if you run into any issues and need to work on your rig at night, it'll be nice to have the extra light, and plus, there is just something nice about symitry
Here's a couple of options on how to wire your trail lights with fuses and relays.
You can have them switched so they are all on or all off.
Switch them so the front 4 are controled seperate from the rear
Or, you can wire it up so you can do the front seperate from the sides, and then tie the rears into your back-up lights so they only come on when backing up.
