trail lights
Really?
it looks the same to me :confused:
I dunno how to quote attachments, but the 85 and 86 prong is wired backwards in the second diagram....
Rick
Are you talking about the second diagram in post 15 or post 16?
I thought you were talking about mislabling the switches "front" and "Rear".
In post 15, the one with the fog/driving lights - I didn't do that dwg. It's from the second link I posted above it (http://www.classictruckshop.com/club...h/foglites.htm). It does show grounding the 85 terminal rather than grounding the 86 terminal, which is actually fine. It doesn't matter which one is grounded and which one has switched power, as long as one of the two is powered and one is grounded.
from http://www.bcae1.com/relays.htm
"Remember that the relay coil has to have a difference of potential between terminals 85 and 86 in order for the coil to pull the armature in/down. This means that you may apply battery voltage to either terminal 85 OR 86 and then ground the OTHER terminal. The positive battery voltage OR the ground connection may be broken to make relay switch terminals (87 to 87a). "
or - from here
http://www.partsexpress.com/resources/relays.html
"Connections
The terminals of a relay are defined as follows:
30 is the common or input voltage (or ground) to be switched.
87a is the normally closed connection (can be used as a switched voltage output when the relay is at rest). (This terminal offers no voltage when the relay is energized.)
87 is the normally open connection (switched voltage output when the relay is energized).
85 is connected to the ground of the triggering voltage.
86 is connected to the positive 12V of the triggering voltage.
Note: in many cases, the connection of pins 85 and 86 can be interchangeable, but NOT if there is a diode wired across the coil. Below are several common examples of how relays are commonly used:"
If you have a relay with a built in quenching diode, then the polarity of the coil hookup does matter. Bosch relays don't have a diode in them - you can add one with a relay socket that already has one in it though
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=330-076
It's just to avoid voltage spikes when you turn off the relay and the coil de-energizes. More of a big deal when you're switching electronic stuff, not so much when doing lights.
Here's an interesting way of wiring lights -
http://www.accessconnect.com/fog_driving_lights_wiring.htm
Basically instead of using a key'd power source for your switch, you pull power from either high beams or low beams. The idea being you wouldn't want driving lights on unless your high beams are on, or your fog lights on unless your low beams were on. I can see the high beam deal for driving lights, not so much on the fogs, but hey, to each their own.
Figure out how you want them to operate, and then sketch up a diagram - if you're unsure (general you, not a specific you) - post it up, someone will be happy to evaluate it. There are lots of options...
Do you want them only to operate when ignition is on?
Do you want them to operate when ignition is in acc. possition?
Do you want them only to operate when headlights are on?
Only when high beams are on?
Do you want to be able to control fronts, sides and back individually, or is all or nothing o.k.?
Do you want them tied into back-up lamps?
Do you want them to come on with back-up lamps, but then also have the ability to turn them on seperately from back-up lamps?
Do you want the normal operation to only work with the key'd source, and then a secondary mode where you can run them with the ignition off? Perhaps for lighting camp site for set-up?
If you want to simplify a bit, and want all on or all off, go for a continuous duty solenoid. It's basically the same thing as a relay, just will stand up to a lot more current - like this 85 amp solenoidd
http://www.delcity.net/delcity/servlet/catalog?parentid=790160&page=1
actually, if you're running a whole bunch of lights and accessories, a master solenoid wouldn't be a bad idea. Instead of having lots of wires from the battery with individual fuses, put in one big fuse or breaker, run it to the solenoid, then from there have your individual fuses and feed wires. Why would you want to do this? Well, if you want to run rock lights with multiple control (front, back, side), and you have some rack mounted work lights (for setting up camp) and you have some fogs or driving lights ect. you can wire them all for operation straight from the batery and have one master switch in the truck that would shut down the solenoid and cut power to everything. The problem always with not using a keyed source, especially with lots of accessories, is remembering to turn them all off so you don't run your battery down. Run them all from a master solenoid, and it's easier to remember to kill one switch to knock everything out. Maybe that's just over thinking the whole thing too.... But hey, if ya' wanna, you can do it....
Are you talking about the second diagram in post 15 or post 16?[/b]
15
I always use the 85 as a ground for basic accessory wiring for this very reason :doh:
15
good practice. I quite honestly had no idea about the diodes till I started searching and reading. My interest in the thread and why I put a mild effort into it is I'm going to be mounting trail lights as well, and would need to plan out the wiring eventually anyway - I only have 5 items on the to-do list before that though :doh:
