Trail help control arm bolt
Kansas
i lost the rear most axle side control arm bolt yesterday running wheeler lake. I have a replacement bolt but cannot get the holes to line up. I was able to drive it back to camp with just the one bolt in the radius arm but am not wild about my 500 mile return trip home. Looking for ideas how to get it lines up. I have a bottle jack and a hi lift. Also have sore castor correction brackets installed on the axle.
You need to take a strap wrap around axle one end strap the other end to cross member then pull it into place
Nope, it can be lined up with the weight of the truck on it.
I would try pressing on the brakes with the engine running and putting it in drive or reverse depending on which way the axle needs to move to line the holes up. A ratchet strap, your winch or your jacks could be used too if you're not comfortable with using the engine to move it.
Good seggestion above with motor.
Ive used ratchet straps to line holes up laterally and still needed to twist the axle housing to get the vertical alingnment. I Used a pry bar but maybe tip of high lift would fit under coil bucket as well to allow leverage to rotate housing to align.
Good luck.
When my upper rear control arms (both of them, at the same time) "disconnected" on the Dusy in 2013, ratchet straps saved the day..... Along with some welds from @Inverness
:lol:
Are you still at wheeler lake and did you ever get this fixed? I happen to be heading there tomorrow night and could bring parts or anything really. Let me know, would be happy to help!
Man I really appreciate that offer, we got down from wheeler. Broke the sway bar mount at the axle side, sway bar took out a brake hardline and we lost our brakes close to the top. A couple hours hiking and a trip to Napa in FairPlay got us going again. Noticed the control arm bolt missing when we got back to camp.
Going to try to make it to Redline Land Cruisers @RLMS in the morning and see if they are willing to install the control arm bolt for me. We tried to get it back at camp but just don't have the tools here to line everything up. This really kills me as its a 10 minute job at home but I'm 500 miles away from my shop. I've heard nothing but good things about these guys so I'm going to give them a shot.
Also, if your intending to go to wheeler lake, I wouldn't. That trail is so washed out and horrible that it's not even enjoyable. The first couple of obstacles right up to the big crack are fun. After that you are just driving over beach ball sized boulders the whole way to the top and back. I hit every piece of armor except my front bumper. If you don't have full armor on your 80 then expect some body damage.
I hope that you are able to get it all squared away and thanks for the input on the trail! Still going to go run it though haha I've been through much harder trail like the rubicon without body damage so I'm not worried about wheeler. I just hope bowling ball hill is semi dry this time around. Last time it was a wet mush. Hope the rest of your trip goes smoothly!
That makes me want to go, why would that be bad?
Made it down to Colorado Springs and stopped into @RLMS redline land cruisers. Justin was the absolute man and got me back on the road with all my control arm bolts in less than 30 minutes. Definitely the right decision not to limp it home as we drove over 300 miles with a 45mph+ sustained crosswind !
Glad you made it and got it fixed!
<snip>
▲Another▲ good reason to run sway bar disconnects, no broken mounts along with better flex:)
For future reference, carry a tapered drift of the same diameter bolts for this very purpose. I currently run Johnny Joints on a 3 link and use a tapered drift the size of the bolts to line things up during maintenance and replacement; makes life a hell of a lot easier. You just hammer the drift through to align the holes and use the bolt to hammer the drift out...Viola...bolt in suspension with minimal effort.
