Toyocom OBD1 reader review
Yup! I ordered mine yesterday afternoon. I cant wait to try it out. This will bring the mighty 3FE into the 21st century!:cool:
Has anyone got one working on the 3FE yet?
JF told me that there is a wiring mod needed inside the ECU for the 3FE. He will give me the details when I'm ready to do the work.
Oh nice, I use mine daily and have found it invaluable for troubleshooting.
Why can I not find the button to erase code just read
I found an OBD1 Toyocom plugged in to my truck, tucked down by the air compressor. Do I need anything special other than an Android device to use it?
It's pairing by BT or wifi, so doesn't need a sim or anything correct? We only have iOS devices over here so this would be dedicated to Toyocom and maybe offline maps of some sort that I can sync on wifi.
How do I get cel info? I don't have a display option for it and I have a cel on.
Yes it pulls/reads codes, you have to tap on it. I forget which one exactly but try the TE1+E1.
I don't recall that it'll give you CEL info...you probably need to do the old school terminal jumper and read the flashes trick.
Wrong again 🤷‍♂️
There were 2 types of toyobd1. The older version (with connector pigtail) called Toyocom can read your check engine codes while his most current toyobd1 (OBD1READ)without the pre-wired plug does not read codes.
