Totaled/rolled 40 value
RDU, NC
A few weeks ago, I rolled my 40 onroad. The fiberglass top is trash, as is the driver's side hardtop side and the windshield + frame. The passenger side hardtop side is slightly bent but salvageable, same with the rear hatch.
Every body panel is dented. I pried up the front fenders to drive it. Frame seems straight, no damage. Radiator must be replaced.
It's a '71, F155, 3-speed with a new Aisin clutch and transmission/transfer rebuild, 95% stock. Has recent front brake cylinders, new Cooper AT3's, refreshed stock suspension (used springs + new OEM shocks + shackles and bushings), all new steering rod ends. The 40 still runs great, steers, stops fine. There was not much rust on it, the rear sill + lower quarters need replaced and I have the parts for that; there's a little rust on each front fender and each rocker. The interior was tattered and in need of reupholstery. I have numerous spares parts to go with it.
My conscience won't allow me to send it to the crusher; however, selling it for <$1k is unappealing. I am very curious about any input on possible value. Sorry for so many photos, there's even more in my media gallery.
full
full
full
full
full
full
full
full
full
full
Looks like you were pretty effective at getting every piece of sheet metal. If the frame is straight, a clean, titled rolling chassis is good for about $1000 (depending on region of the country). To the right guy, maybe $1,200 to $1,500.
That will buff right out.
Actually, I don't have the skills but there are threads in this forum where men take 40's in worse condition than that and make them impeccable. Don't let it get dragged away to a junk yard no matter what.
port a power and a torch to the quarters, most of that can be straightened, find a stock one and get some measurements so you know how much it moved. I fixed one that was in worse shape years ago, it looks like a nice rust free(low rust) cruiser. You will need another hardtop as the amount of work to fix that one is way too much,
Look for a tub to replace yours. Bolt on sheet metal can be found with some patience.
I have seen worse come back from the dead.
I have tore up a fender worse that the ones you show and hammered it out.
If you don't have a port a power a good sturdy tree and a come-along can do wonders.
Concentrate on the body and slap a rag top on it.
Sorry to see this. I rolled my ‘76 about 20 years ago and revived it. I never did get another hard top, but I got another hood, windshield frame, and fenders and the thing was still a gem.
The other option is to part it out...you can make quite a bit of money, but WE as a community lose another driver.
Best of luck to you and I hope everyone is ok!
If you were closer to me I would jump at the chance to buy that for 1k. The salvageable parts alone are worth a lot more than that. I hope you decide to keep and restore it.
Thank you all for your thoughts on this.
No-one else was involved, and I walked away with broken ribs. Emergency stop from 45 due to another idiot driver (who took off), started to slide and hit a curb which popped me up and started the roll.
I honestly had no idea what this 40 would be worth, and as a runner I'm disappointed; but you all know better than me.
Don't have much appetite to fix it all up, but considering current value it may be best for me to do that. No body work tools or experience either.
Funny thing is I have a new MT Jackson cage, new Real Steel soft top bows, and unused OCD soft- and bikini tops I found on here a few months ago. Guess that makes this all a no-brainer...
I remember you posting this up a while back and was wondering how things were going with the ‘rollover’ aftermath!
Save that old girl... she may likely have saved you - could’ve been worse than broken ribs if you’d been in a lesser vehicle! ;)
I figured it was from an emergency stop.
It took me years to learn how to drive my FJ40.
Had the ass end come around a couple of times when slamming on the brakes.
One of the problems was to much air in the tires. Especially the rears.
These rigs are so short good brakes can sometimes be considered a liability.
if you have lost enthusiasm, give it a while before you get rid of it. Your attitude may change in a week to a month. Probably after those ribs heal a bit.
If you do decide to go for the repair be sure you have the time, money and are committed to see it through. Otherwise if you burn out half way through you will have lost time and money on top of where you stand now.
Desire is the big factor. With motivation you can learn skills and just think of all the cool tools you can convince your wife you need.
If you are fairly young then it would be a good learning project with a rewarding product at the end.
At my age, if I were to stack my Toy up I wouldn't try to fix it but 15-20 years ago I would have jumped right in and started straightening things.
My philosophy has always been if it it already broke then what have you got to lose.
wish the best of luck to you.
Looks like the cowl is good. Lots of good parts on their, want you don't want to fix you should sell. What are your intentions ultimate owning a fj40? Did u want to make this a show truck, a beater, or a nice restored driver? How much money and time u want to put in it? If u want a beater u could probably replace the windshield frame and put a soft top on it. The bottom half of the doors look good, so u could just look for a set of doors with good upper halfs and have good doors. Then drive as is. Or for a nicer fix A 3/4 tub would fix most the damage with little work but be expensive. Replacing bent panels would be less expensive but more labor.
