Isn’t the stock operation on the FJ62 to have all four lights on when the highbeams are on? That’s the way my truck’s always operated - flip on the highs and all 4 headlights are on.The kit we have developed only uses them in the stock form. That is a function that can be done but it requires additional wiring not provided by this kit.
Is that not how it will be if I install the Torfab LEDs?
Best upgrade ever when it comes to safety. Super easy to do. Only regret ... Not upgrading the rest of my bulbs to LED at the same time.
Any chance @NookShneer can show how you recommend the resistor be mounted with detailed description/required mounting hardware? Just ordered and what to make sure I have everything planned out.
Thanks
Here is the location in the install video. Others have mounted them a little higher up on the fender bolts.
Important thing is to make sure that the ground wire is under the bolt head and that you are getting a good ground.
Resister from Amazon is what I was asking about... Thanks
Thanks, if you come across a photo of that, please send my way, I am by no means a mechanic, but I'm above-average "handy". Mount with screws?Sorry about that. This is the one we recommend. You would need to mount to the fender in a place that allows heat to disipate as they get warm when on. I would recommend trying to place on the raised rail with the emissions equipment if possible to prevent drilling into the fender. Sorry I don't have any photos of this installed.
