- Thread starter
- #101
Hmmm, probably not. I think I am going to go ahead and get the rotors on the rear as well while I am taking up the garage and driveway.
So I figure I can just cruise over to NAPA and get some, wrong! I head over to Toyota Mission Gorge and they don't have any but think that they have one for a 6 cyl head that will work. It's pretty damn close and close enough for me but they only have 1 and of course I need 2!
didn't do that very thing! SO I had to take the whole thing apart again all the way to removing the spindle, opening up the knuckle cavity to coat the damn spindle!!! So by the time I got back to the brakes, I got the old pads out of the front it was time to meet the family again for dinner!
had to fix this problem by getting a used pumpkin, guess what? I had to revisit the axle yet another time as a result since I couldn't leave the truck on stands, as it was my daily driver at that time. Yes used to break more things than I fixed, but I think I learned from my mistakes and am getting better at this.
all the best. She seems really nice. Don't screw it up
runs out knowing it was ME..... I thought it was the PS front but she says it's the PS rear. Pull the wheel, no markings on the rotors, pads look good and there is a space between rotor and pad. So I think it has something to do with the Parking break because removing those things we popped the pins out of those spring things.I didn't find any of that info on this board or in the FSM. I found bits and pieces but yours right their is the first full description I have gotten.
I had the e-brake off before removing but couldn't find the damn sprocket through the hole. The little pins shot off of the little springs and plate. We tried to repair the little tabs that hold the pins with a hammer. But I am suspecting I need to adjust that sprocket. I assume that is my problem.
Description in the FSM is not very good and didn't make sense until AFTER I'd done things that the FSM covered before it made any sense at all.
And yes the FSM does tell you to rotate the sprocket but it doesn't tell you how to find the bastard. Yeah I will order new pins and spring plates when I go to the dealer to pick up the caliper washer I no longer need.Wait, what is this?!?Bluetribal said:...And last but not least, a teaser of the SD Trux custom machined OEM rotors...
. But you guys are right, I did learn quite a bit and I am trying not to knee-jerk to any feelings. A few things I learned about this site is that it can give you ignorant confidence, you will look stupid, their are stupid questions but you have to ask them, and last but not least no picture will do it justice.
