took me long enough
sittin on the couch in UT
took me long enough
but i finally bought me a star, did i get the record of number of posts without a star? anyway better post some pics and tech before i get the boot.
if i flip the rear springs will i loose suspension travel at all,
same with the front?
i don't see why you would lose any articulation...the overall spring cycle is not changing any, so the changes in height will be the same.
ok... sorry for the dumb question... but why do people flip them over?
not so much over but flip them around, extends the wheel base of the vehicle.
Noob question....
Driveshaft length concerns? Or are we only talking an inch or two here? A FJ40 with a slightly longer wheelbase looks cool...
Missed getting the red one in the middle of the page (see link below) by a weekend. Talked to the owner the Thursday before Memorial Day and planned to see it on the Tues after...New owner had a shipping CO pick it up that Saturday :frown:
Wasn't crazy about the paint but could have lived with it...I think Greg @ VOR ended up with it :mad:
http://www.enchantedtoyotas.com/fj40.html
camcruiser13 said:
good, im flippin them then
what i said makes sense, right?
i mean, you're not changing the spring itself, so as long as you don't have a physical limit (i.e. tire rub, bumpstop) in a different place, the articulation should be the same...
i think there may be some driveshaft concerns if you move your hangers, but if you're just flippin em, i think you're fine...this has been gone over a bunch in the past, and i've gotten all my knowledge from those earlier threads
malphrus
malphrus
My understanding is if you flip the springs, you gain length/wheelbase. That has got to push the axles forward on the front and rearward at the rear right? Otherwise, why do it? And, if the axles move then the driveshaft length is affected. If we're only talking an inch or two then I can't imagine that would be a problem unless the driveshaft is too short to begin with or you are at full extension.
What kind of length does one gain from reversing the springs?
yes there is driveline concerns i will be lenghthening them i have to, when i went soa they barely hung in there now the front has slipped out, the lentgh from the cenetr pin is 20 one way and 24 the other so you do the math itll move them out quiet a bit.
Is that applicable to both front and rear springs? So, you would gain 8" overall of wheelbase by flipping/reversing the springs?
Any issues with shock attachment, brake line length, etc? Sounds like fun :eek:
i have yet to reach that road, right now my front is torn aprt, see sr thread
yeah im flippin both so far so good, my brakelines are all fine, but i made them and bent them to where i wanted so ther good, shock mount on front axle may have to be urned 180 and moved a little but we'll see
Cool...I'll be watching to see how it all turns out! A little extra wheelbase would be a good thing IMO.
your not going to get 8" of wheelbase just from flipping the rears. you'll get 4 give or take an 1" because of the the flatness or lack there of in your springs. if your worried about the military wrap being on the correct side, flip that one leaf and redrill the hole to match the others. however if you flip both you should gain around 8"
metalonmetal said:
post #10 = tech thread visual of the year.
ahhh yeahh
you like that
