So I had a radiator go bad and I replaced it with a CSF all metal after the first 2 aluminum ones I ordered wouldn't fit. I've like the quality of the unit but its been running hot since I did it, not too hot around town and because its still spring in utah but if I go up into the mountains I would see 199 and 195 around town. I replaced my fan clutch with a new Aisin blue hub thinking that my old one was toast and had someone flush and burp the radiator. This last weekend I took it to Moab and even though the temps were mild (60's) I hit 221 before hitting the heater going up over price canyon. any hill at all and temps would climb up to around 208-210, without AC on. Down there I removed my light bar in front of the grill, double checked my fan shroud (fitting snug now) and tried to burp the system again as when I arrived my res tank was sucked dry. Still hot, in fact driving up shaffer trail I had to crank the heat to keep in below 220. The fan is roaring at idle, but I can't hear it on the road as roaring. It seems to me like the fan clutch is working because if I stop when its hot and open the hood the check on things I raise the revs and I hear it roaring again and the temps come down. Its acting a lot like when I first bought the truck and the radiator was bad. Hot on the highways mostly and slow to bleed heat.
Is there a chance the radiator I bought could be faulty? Its not leaking. Can you reverse the flow to the trans heat exchanger by mistake? The aux cooler felt really hot. Any other thoughts? The T-stat isn't that old.
