My best investment was left hand drill bits, place drill in reverse and WHAMO watch it un-screw.........
How long have you lived in the North East?
Finally got a new distributor for the pig. Found an HEI one that has a toyota specific gear on it so I wouldn't have to modify a GM one to fit.
Pulled the old GM dizzy and all the teeth on the gear were gone. Basically the highway driving shredded the worn down teeth since the GM dizzy teeth are standard alignment as opposed to metric.
Turned the motor by hand and had my mechanic look inside the hole and he said everything looked ok.
Gonna pull the plugs tomorrow afternoon, install the new one, and try to figger out the timing since the rotor was just spinning away and the alignment references are gone. Gonna change the oil too for good measure
Never done a distributor. Least I won't likely have to deal with this again for a while
Put another new fuel pump in the 81 toyota cressida... this one didn't leak. i was so excited i didn't even pick up i just started driving it. i rallied the back road and e-braked in my buddy's driveway then noticed my temp gauge was pegs so i drove back to the shop to find that it had no coolant in it. it took 2 gallons. then it started to run like a bag full of smashed a$$. the cat is plugged up..... seems like i'll never get this thing into the shop to weld the ass end up.
I have two Warn M8000 winches...one is 20 years old and the other is just over a year. Used the old one 5 times just this past weekend and has never let me down. The newer winch in Sheri's FJC started pulling intermittently last FG, until it finally wouldn't pull in at all. Finally troubleshot and found of the solenoids bad. Less than a year old....used three times.....Hecho in Mexico. Picked up new solenoid from NAPA...made in China. Hope this one is more reliable. Putting it all back together tomorrow.
