1HZ he will be driving the truck for a while to work out the possible bugs then i'm going to turbo charge it. i still have to put E-Lockers and lock out hubs in it. still have to figure out how to make brackets and such to hook up the cruise control and have to charge the A/C system. so i guess it's not really complete but it looks cool.
After Kina's I had steering trouble, so I tore it out and started over.
and a little
I was able to use my
skillz and complete the task.
like a porshe.
The pump was new from PSC and I sent them my 4.25 turn box to rebuild.
Kind of expecting it since around 50% of any bolt I touch on this truck snaps off. Looking for opinions. I plan on taking the manifolds off the block (assuming no more bolts snap) then either replacing the manifolds or having a machine shop drill out, helicoil the originals. Surely, somebody has experienced this already?take the manifold off. hold a nut over the broken stud and weld the stud to the nut through the center. works almost every time. if it's a real bugger it might take a few tries. but it heats everything up and gives you a second chance with a wrench. if all else fails i know James at cruiserparts.net has a couple hundred of these things kicking around.
No welder, but once I pull the old down pipe off, there may be enough stud remaining to double nut them out. I'm hopeful since removing the manifolds is SO much more work. Thanks for the tip Josh.
If you want to borrow mine let me know that way your not out the bucks......
