- Joined
- Dec 26, 2005
- Threads
- 15
- Messages
- 77
So about a month ago, I decided to figure out a vacumn hose leak on my 78 "2F" 55. I soon figured out it was a timing issue and would go ahead and address that issue. Soon after I found that I may have a damaged crankshaft pulley. So I did the ebay thing and got the replacement pulley, new front seal and new timing gear cover from toyota. Then went to pull the pulley, found that the pulley was damaged, the keyway was damaged and the keyway slot was damaged.
So I went to a local cruiser shop in Denver, the guy there had no suggestions other than replacing the engine. At this time I haven't decided to cross into the dark side. I don't want to replace with a 327 or 350. There are a number of high mileage 2F on craigslist, but I would be replacing a tired engine with a tired engine. After contacting a good friend about a machine shop, the machine shop has a contact and replace the Crankshaft.
Now what I thought originally was a vacumn leak is a crankshaft, rod bearing, main bears, keyway, pulley, seals, gaskets, and I might as well do the clutch while I'm in there. This also gave me the excuse to buy a engine hoist.
So here is my question, should I replace the crank and all effect on the engine I have or get another 2F and put fresh gaskets and seals on it. I think in the end, they will both cost about the same.
Either way, I will need to buy a gasket kit. Does anyone have a reccomendation for a company to purchase from. I have seen plenty of entries that replace the front and rear seals with original toyota parts, what about the rest. Who has the better gasket kits? SOR, CCOT, MAF, or JT? Same question on the clutch? Has anyone used the center force standard? I heard there is a issue with the fly wheel if you use the double friction.
I'm looking for opinions. Thank you for your thoughts...
FJ 60 and since then not a bit of leakage + he recommended and sent the Felpro gasket....if momma is happy then I can work on the piggy
