To Lipstick And Beyond
@GJCruiser
There should be some freeze plugs behind the side cover. It’s possible one failed or is completely out.
It would have to be a rather good sized hole or missing freeze plug to fill up while pouring in.
Help me understand that. Freeze plugs are visible behind side cover or hidden and exposed by removing side cover? I'm looking for an internal leak between oil and water.
Drained dirty water, then thin oil from crankcase. Removed all plugs, ran compression test with all plugs out, on battery charger, crank five rotations, and read. Altitude 6200 feet.
FJBen, I think you mean a freeze plug in rear of the head.? I'll go look again but I have NO external leaks.
I'm with @scrapdaddy could be as simple as a head gasket, the only part that I pondered was how fas you were filling and loosing liquid - a bit of pressurized seepage is a normal HG symptom, free flowing I'd think less so.
If it's the HG, it would explain your compression numbers, don't love #2 for the fact that its low and not the same as the rest. If you have done a visual around the block and head though and the freeze plugs are intact, I'd think that the HG is your most likely culprit.
I agree #2 is low. From memory from about two years ago, that was not the case. Plugs 2,3, and 5 are sooty, but not wet. I can confirm I cannot fill rad, water goes straight to pan. Someone over on 40/55 tech mentioned oil cooler, which I have. I don't understand how a head gasket leak could cause my symtoms without pressure. The oil cooler is an exchanger and I could see a failure mixing there w/o pressure. Any experience on cooler failures here?
That's a good theory - the cooler would be on the outside, weaker metal and have been filled with water during the -15 days, that makes more sense. I agree too, the flow rate was puzzling to me.
Can you bypass the the cooler with a short hose and see if the cooling system holds fluid?
I’d pull that side cover. If a freeze plug is bad in there, Coolant would go straight down into rocker arm crank case.
If it was cooler I think it would've split and spill on floor but might be wrong. By pass cooler is good idea. Is the cool going into pan real fast??? If it was I would say 1 or more of the freeze plugs behind pushrod inspection plate. There are 4 freeze plugs on each side of block and 2 in rear of block and 2 in front of carb on D/S where stovebolts are. I'm betting behind pushrood inspection plate 🤔🧐😉
So I'm still ignorant--there are freeze plugs behind the side cover in the lifter inspection area? I'll go look for photos.
