TLC4x4 Brake Calipers Who has them?
If he waited for those, I would bet that he would not ever operate the truck.
I bet we see Dorothy's balloon from the Wizard of Oz have these hanging on the side soon....
More White Elephants....;)
foxfab said:
If you were going for bling, you shoulda gone with Marlin's 6 stud knuckle setup :D
Poser said:
In the parts you are replacing, compared to what you are looking to get rid of?
DUH! ;)
Parts are the same.
I bought everything else and finished all the cast parts and then swap it all out in a day.
They are from a 79 with 47k
:cool:
Hummmmm, Good luck with that.....:D:flipoff2::D
Fox, I will have your decals in the mail in the morning............I just posted them in my eBay store. Thanks again...........
I agree dgangle. I wish there was as much crap for TLC owners to wade through as Heep owners do. There is some seriously slick and ingenious stuff coming out for those guys. I hope the FJ Cruiser evolves in to that kind of aftermarket support.
AATLS1X-
Where are some pics of the rest of it? It sounds top of the line.
awp
Pics of the other parts.
Last November there was only 2 OE Chrome wheels on the planet. We had a sales event like any other that previous month through December. My dist rep had told me that if I won he/Toyota would buy me anything for my Land Cruiser......I thought long and hard after talking with my parts mgr and had a question? Hey call Toyota and see if they would have 3 made for me......Well I about fell out of my chair when Toyota of Japan said sure we would love to!
I won the sales event and my rep asked what i wanted for my ride. I said just a set of OE wheels would be cool. He said ok, get with your parts guy and get it handled.....He did not know they were $335.00 a piece (retail) and I get the original caps as well...... thats my cool story fro a rare item.....
AATLAS1X said:
...What are the best pads to use, I have tried to find HP pads like Hawk and other run of the mill brands with no luck. It will be a daily driver so I want stopping power!...
I've used and recommend http://praisedynobrake.com/ parts. PDB uses kevlar in their composite to enable more sparing use of metallic particles which, in turn, they claim produces less wear to rotors/drums thru less metal to metal contact and less heat– all things being equal. For the last 12 years, I've found PDB pads and shoes to be quiet, low dust (no carbon black & barely noticeable), strong stopping, and very heat resistent due to the heat handling qualities of kevlar.
dgangle said:
I just got off the phone with TLC. The 'monster calipers' have four 40mm pistons. Based upon this, I can see no performance advantage over using the 92-94 V6 4 Runner calipers. As a disadvantage, the TLC's use the smaller FJ40 pad which will wear faster as compaired to the larger 4 Runner...[/url]
I'm no brake engineer, but I'd bet that one couldn't argue with more pad surface = more stopping ability. Kinda like the "no substitute for cubic inches" argument. But I beg to differ on the SSBC/TLC calipers having no performance advantage over the foreskin calipers.
The aluminum calipers will:
1. dissipate heat better.
2. reduce unsprung weight.
3. are probably stiffer bodied to keep better pad alignment.
4. May produce less pad and rotor wear as a result of #1 and #3.
AATLAS1X said:
...I also bought the big vented drilled rotors from Brembo and cant wait to see what they do...
I recommend against both cross-drilled and sloted rotors. The slots REDUCE stopping power but increase cooling. The slots help throw out brake dust away from the rotor surface to provide the next braking action a "clean" rotor. These are great attributes for racing, but not for street vehicles. Maybe one could make a case for slotted rotors on a tow vehicle for downhill grades with an auto trans. And the holes often crack, collect crap, and rust which can contaminate the pads. Racers don't care since they use new pads every race (or so if on a tight budget). I recommend you return the rotors and purchase one of the following in order of cost from least to most expensive:
1. Stock rotors.
2. Stock rotors and have them cryo'd.
3. Nodular iron rotors (available thru PDB, but I don't know if for FJs)
4. Cryo'd nodular iron rotors (again thru PDB).
I will also see if there is a rear shoe worth boying over OEM.
Again, I recommend PDB.
DGANGLE, I think you need to order up a set for your ride...............
He's not worthy. :D
Wow, alot of great advise here. I will re-think my braking thoughts.
PBD is that what I thought PBR of Australia or have I have I had to many tonight??
It was Jello wrestling and .25 cent Jello shots tonight....................................
AATLAS1X said:
...PBD is that what I thought PBR of Australia or have I have I had to many tonight??....
I just abreviated Praise Dyno Brake to "PDB" to save typing. It's not PBR which is the Aussie brake supplier in MAF catalogs.
BTW, I should have said that the cross-drilled holes add stopping power by providing the pads edges to grip against as the pads try to conform into the hole under pressure, but the extra grip on sharp edges under wheel rotation also wears pads faster. It's all in what you want. I think street & trail only trucks need more rotor surface for better stopping which stock rotors have over slotted/drilled rotors. How often does a street truck see high heat braking like road track racers experience?
I saw that you were spending some coin already, so I recommended PDB stuff even though they are expensive. Actually, I don't think they are more expensive for a vehicle kept long term since their stuff lasts longer than auto parts premium brake parts and perhaps some performance products. And PDB composite is easier on rotors with improvement in stopping power and heat capacity over stock replacement brake parts. There's some speculation in there, fo sure.
BTW, I do not like the concept of cross drilled slotted rotors either. they have their place (porsche) but not on a 40..
I've always heard, for rotors-
vented - good
slotted - good (?)
drilled - bad
for our application, but have also heard many say OEM (vented, at least the FJ62s) are just fine.
At any rate, I'm upgrading to pickup/4runner IFS calipers on the 62. They've bigger pads and have a little finning for heat dissipation. Cheap, $25 used for a pair. Maybe I'll paint 'em red or yellow and pretend I'm Speed Racer? :D
FJ80 master cylinder to push the fluid.
