TJM USA Builds some fun....In 3 Nights!
Rear Adjustable Track bar installed..... Pretty easy here, we were little worried about the OEM bolt on the drivers side as the nut is welded inside the bracket out of site, but again, a little gentle slow impact gun persuasion had it come out in one piece. I would for sure suggest soaking overnight before doing this.... We lucked out for sure!!
Well we're one rear sway bar re-install and a couple of vent lines from being done with suspension! Still have to go back and torque things up, but were feeling pretty positive that we can get it done and to Expo! Time to get some rest and we will get on it again tomorrow.....
no fair using a lift...at least half the time is cut out by not having to crawl under and out and back under
looking good though!
Itchy, We're going to try a recommendation and try the larger front on first.... We will see....
Got it, thanks! Dang...I hope the rear one isn't such a PITA like the front one!
Erased message
It's time......Lunchtime TJM Airtec Snorkel install!! Remove the stock air cleaner assemble, pretty easy just some vacuum lines and 3- 13mm bolts... Next our instructions say remove front turn signal light.... Not sure why, so we left it alone, as in don't remove it! We thought it was to remove the inner OEM air intake, but the bolt hole here is all that's needed to remove. Take the 12mm bolt out and slide the OEM snout out! Once your all clear and had a bite of sandwich move on to the template....
