Tire Pressure recommendation
Hi @gaijin, can you please help me with tire pressure for BFG AT KO3 285/60/18 on 2020 LC 200 with HE BBS wheels, please?
I find the KO3 in an LT-Metric size LT285/60R18 118/115S Load Range D.
If that is your tire, then the RCTIP (Recommended Cold* Tire Inflation Pressure) for those LT285/60R18 tires on your LC200 is 46psi F/R.
* According to Toyota:
Tire Pressure vs. Tire Temperature
Tire temperature is dependent on “cold” tire pressure, driving distance and speed, ambient temperature and road surface temperature. As the temperature of the tire changes, air in the tire expands and contracts, changing the tire’s air pressure. The cold tire pressure for all Toyota models will vary and will need to be adjusted accordingly.
“Cold” tire pressure, as shown on the tire pressure label on our vehicles, is generally considered to be the pressure in a tire that has not been driven in the past 4 hours and has been parked outdoors.
And don't forget to re-initialize your TPMS system.
HTH
Hi @gaijin can you help me with tire pressure for a 2021 LC with LT285 65 18 Falken Wildpeak AT4W please?
Sure!
The RCTIP (Recommended Cold* Tire Inflation Pressure) for those LT285/65R18 tires on your LC200 is 42psi F/R.
HTH
@gaijin Apologies if I missed it in my search, but I'm looking for recommended tire pressure for LT285/75R17 Toyo Open Country AT3 Load Range C for my 2016 Lexus LX 570. So far I'm only finding your recs for load range E in this thread or LC200s.
All LT285/75R17 tires have the same RCTIP (Recommended Cold* Tire Inflation Pressure) spec, irrespective of Load Range.
Toyota specs a Tire Load Limit of 2286 lbs for the LC200 which, for the LT285/75R17 tires, yields a RCTIP of 37psi Front/Rear
Toyota specs a Tire Load Limit of 2105 lbs for the LX570 which, for the LT285/75R17 tires, yields a RCTIP of 35psi Front/Rear
Take your pick.
*From Toyota:
HTH
@gaijin 285/65/18 Falken Wildpeak A/T3W 116T SL, 2019 LC200, 3" lift, stock wheels no extra weight. Do pull a 2500 lb boat. TIA!
@gaijin looking for 285/75-18 load range E. Much appreciated!
I need a more detailed description of the tire, and the vehicle on which you are mounting it.
The RCTIP for those 116 Load Index, Standard Load tires on your LC200 is 33psi.
HTH
Toyo AT3 285/75-18. 2017 200, if you need anything specific let me know!
I guess you are referring to the LT285/75R18, right?
The RCTIP for an LT285/75R18 tire on an LC200 is 35psi.
HTH
@gaijin looking for recommendation, Michelin Defender 265/70R18 116T XL on 2017 LX570. Thanks!
Based on Toyota OEM RCTIP (Recommended Cold* Tire Inflation Pressure):
RCTIP for those ISO-Metric 265/70R18 116T XL tires on an LX570 is 34psi F/R
RCTIP for those ISO-Metric 265/70R18 116T XL tires on an LC200 is 38psi F/R
Take your pick.
*According to Toyota:
And don't forget to re-initialize your TPWS.
HTH
Hello @gaijin and other mudders!
I drive a 2009 LX570. Just had to replace the summer tires after only 3 years because of uneven wear to the point that we failed our state inspection. Shop thought maybe it was bad alignment, but they found the alignment was not very far off. Their next guess was that we didn’t rotate them frequently enough...we had been rotating them only when we put them back on in the spring, since we don't drive very much, but it was likely more than 5k miles. An aggravating factor is that each June/July we take a 2000 mile road trip towing a fairly heavy travel trailer with a ProPride hitch.
Our new summer tires are Yokohama Geolandar H/T4 G062, 285/50R20. I'd be grateful for any advice about proper tire inflation, with and without towing. Hoping to get more than 3 summers this time!!!
Thanks so much in advance.
Ben
Wanted to recommendation for a '19LC for Falken AT4W LI: 125, E1 285/65/18. 3" lift, stock tires, no heavy payload, do pull a 2500 boat. TIA!
If you are referring to this tire:
HTH
@gaijin might you be able to offer a tire pressure recommendation for Yokohama Geolandar H/T4 G062, 285/50R20 on a 2009 LX 570?
Many thanks in advance, and sorry if my earlier post was too detailed for this question!
For this tire:
The RCTIP for this ISO-Metric 285/50R20 116V XL tire on your LX570 is 33psi F/R.
HTH
