tips for removing not budging 27mm nut for parking brake drum access?
SoCal - westsiiiide
so, I am replacing my parking brakes and the seal to the transfer case to stop leaking and get my parking brakes back. BUT, I cannot get that 27mm nut holding the parking brake drum on to brake loose. using a 27mm socket in a 1/2 drive and I broke the socket drive while trying to use a braker bar on the socket tool. should it be this hard? I sprayed the area with some WD40, need to go buy another socket drive... but what the heck?
i don't know mine came off way easy with a breaker bar but for some reason 27 mm didn't fit, i had to buy a 1 - 1/8th , if you get craftsman the replace it for free, to point out the obvious make sure your going the right way and that you have un-staked the nut, theres a metal peice you need to take out in order to get it off, and if and when you do i think its torqued to 120 lbs not sure though ... hope it works
Impact, works EVERY TIME!
Guess I would get a better quality breaker bar....if you are twisting off a 1/2" drive..
I have removed them by hand, even with red locktite on the nut...the only time that I have ever seen any of these be a real pain is when someone cross-threaded the nut on... :rolleyes:
Good luck!
-Steve
yeah, it was a cheap no name socket wrench I admit and a home made breaker bar that is a little to big diameter. Actually, I realize now it was a 1/4 drive with a 3/8 adaptor and I poped the back fo the drive head right off and the gizzard went flying all over my floor. I am going to get a better socket wrench right now and a true breaker bar out of pipe.
I have no impact wrench, and I already have the rear drive shaft out, so that is not really an option at the moment unless I put it all back on, go someplace, take it all off, have tem brake it loose, then put ti all back on, drive home, take it all off and do the repair and put it all back on. NOT!
right way? I assume right is tight and left is loose ike most anything else. if I am looking at the back of the rig, I am trying to turn the bolt to the left (or up). :)
as for 'un-staking' the nut. not sure what you mean there. my 1974 manual shows nothing but the nut, washer and a spacer/shim under the nut. no metal piece in my case to take off first (except the drive shaft in front of it all) :)
Right and left get awfully confusing when talking about things that go around in circles...
Counter Clock Wise (CCW) will loosen, CW will tighten.
The nut itself is what gets staked. It is partially deformed with a punch to lay down in a key way cut into the shaft. I prob have a picture of this on a different computer. I can look. I am not sure if they used staked nuts on a '74 - my '78 has them.
I had no trouble getting my parking brake drum off - don't know if I used hand tools or impact...
actually, there are 2 shafts or cutouts on the bolt the nut goes on. down each side of the bolt. the nut DOES seem to have been dented/deformed in at those areas slightly into those shafts. WTF? how the hell do you get those undone? could it be binding up against those shafts? there is nothing in the manual or on any online posts about removing this nut that mention this.
see atttached images. arrows point to the shafts in the bolt and the dents in the nut at or near those shafts. so, WTF do I do about this?
BTW, I broke off a 2nd 3/8 drive. snapped the head right off. this cannot be correct.
Those're staked all right. Get a punch and pop the staked parts out.
not sure what you mean and how to do it? could you better explain how to do it and what I need ot do it?
as I see it, if you push something down those shafts in the bolt, will it not destroy the teeth on the nut?
PabloCruise said:
Yep, those are stake nuts...
I spun mine off w/o doing a thing to the deformed portion.
Others have to grind on them with a grinder or Dremel.
Keep the faith bro - don't get frustrated!
I can beat this, I just need to get pointed in the right direction. I have a dremmel, but what exactly do you grind on? is it not the nut body that is pushed in slightly into the bolts shaft? so, what is there to grind as the issue is the metal in the shaft binding up? or am I seeing this all wrong?
do, you just drive something down those shaft with a hammer? what about the nuts teeth?
I have pried the punched in portion out with a screwdriver or punch. You may destroy the nuts threads or teeth, as you say. You are supposed to replace it with a new nut.
F@#$ - i just broke another 3/8 drive. I think I have the pushed in area pushed back out with a punch and an old screw driver, yet the damn nut will not budge. WTF!!!! what more is one suppose to do?
PabloCruise said:
I hope you are buying these tools at Sears...
h.depot. life time warranty.
now what should I do. I cannot get it to budge. I feel like I have adequately pushed out those areas, but I guess not?
You need at least a 1/2" drive set up to tangle with this....
1/4' and 3/8" is NOT GOING TO DO IT!!! (you have klearly proven this ;) )
The 'tab' is not the issue, you need a bigger TOOL! :)
Good luck!
-Steve
-Steve
your right about a 3/8 drive not cutting it. 3 busted drives in 2 hours! I am on board with moving to a 1/2 drive. but, how will I know when I have clearly gotten the tabs out of the shaft tunnel? as I see it, when I look into shafts, I can see them ramp down and see the end of the ramp. thus, as I see it, I have pushed back the tabs as far back out of the shafts to expose the full ramp. what more is there to push out of the way? yet it still will not budge! I hope a 1/2 drive will cut it. or maybe rent an impact wrench? would that just turn the nut no matter what?
BTW, you do not know me well enough to comment on the size of my tool. only my chick can do that ;)
