- Thread starter
- #21
I'm not attaching that stuff to a borrowed $350 slide hammer. I'll put a whole tire on this Harbor Freight bitch I'm going to buy after the gym
Air die grinder, gloves and a hammer chisel (and a face guard). Inner race and BB's can fall out. Grind a slot almost all the way through the outer race then use the chisel and hammer to chip it out. Works great and is fast. Gloves are for the small needle like shavings that WILL get into your arms and hands. Did I mention the face mask??!?!?
Went to my burn pit and torched off all of the boxes and old s***. One of the shocks blew up and went into the nearby woods and caught them on fire.
The big ass zip ties that come with the headlight kit work really well for the clutch fork.Trophy.
For a 80-84 FJ60 you need to grind out a couple of spots on the bellhousing.
This is a nice trick for stabbing the transmission.
Put a tight strap on the throwout bearing arm and keep it under pressure so it's not flopping around while you are trying to do the mating ritual
Should have videoed me dumping all that coolant into my driveway.That pic would get you arrested in Cali.
