They're interchangeable. My 05 LX has a housing from a 98-02.Potentially stupid question - if I’m swapping in an Eaton locker, does it make a difference whether the front diff assembly is from a 98-99 (OEM 2-pinion 4:30) or an 00-02 (OEM 4-pinion 4:30), or are all 98-02 4:30 diff assemblies with Eaton e-lockers equivalently durable?
Front diff blew on my 99 and I want to make sure it doesn’t happen again. Thinking of getting a cheap used assembly and driving/shipping it to ECGS for an Eaton front locker to be installed.
But not the same ring and pinion gears since the '05 has 4.10's from the factory along with the 5spd AT.They're interchangeable. My 05 LX has a housing from a 98-02.
yup 98-02 is 4.30 gears.But not the same ring and pinion gears since the '05 has 4.10's from the factory along with the 5spd AT.
The drive flange is also different - there's a spline count difference between the 4.30s and 4.10 pinion gear.yup 98-02 is 4.30 gears.
Same. Cruiser Outfitters built my diffs with 4.30s and Eatons. I have no plans to go bigger than 33s on my 07. I’m not sure what year third members they used. I still gotta get my lazy butt to pull my oem diffs and install these locked units.The drive flange is also different - there's a spline count difference between the 4.30s and 4.10 pinion gear.
I actually regeared front/rear to 4.30 and added lockers when I blew my front diff in my '05. Gets everything close to stock with 33s and I got the complete 98-02 diffs *cheap* (like, $400 total for front/rear/T-case).
After grenading the original 2-pinion differential on my '99, I recently replaced it with a 4-pinion differential with an Eaton locker, built by Valley Hybrids. It's controlled by an 80 series dual locker knob switch in place of the original single locker one. I haven't had chance to test it out but I will in a few months. I don't anticipate needing it too often given the type of wheeling that I do, but I feel more confident in having a stronger setup vs. OEM.
Took the truck to Slee and asked them to do the 4pinion and they said 'why not add an air locker while we're at it' and I agreed@cbranch , @Exiled
I think I'm missing something here...why are you guys starting with 4 pinion diffs just to then put in lockers? It's my understanding that the installation of a locker completely replaces the pinion gears whether 2 or 4 so it doesn't matter what you start with as long as the ring and pinion gear ratios match up to the rear diff.
AFAIK that's correct.@cbranch , @Exiled
Exactly. So there’s no point starting with a 4 pinion instead of a 2 unless there was other damage.AFAIK that's correct.
So not sure how someone would
The locker replaces the entire center minus the R/P.
It doesn't care about OEM pinions and there's no need for them after the swap, it has its own.
I'm curious, what's the rationale behind the additional air tank?I do need to add an air tank as well. I do have the factory rear locker too. So if you're on the fence about doing it and your wheeling justifies it just do it !
