Thought - Water Jacketed intake
I forget offhand, but either @FirstToy or another ceramic coated his housing, and another added the NASA-type reflective jacketed insulation adhesive sheets.
I'd see how that worked for them, or for what you're talking just add the intercooler part of @djsixbillion old S/C'ed motor. His 80 was K.I.A., so he may not check here anymore, but his album should still be around.
FirstToy covered his canister top. I covered the entire airfilter canister with heat shielding.
Was there a write-up or photos on this?
It's a long stupid read:
Engine Rebuilding options for S/C
But here are the pics of the filter canister and then pics of the ceramic coated exhaust Manifolds (also to reduce heat)
I'd need to run the numbers, the Charts suggest that 3/8th copper pipe should be able to take about 100 W/M^2 at these temp deltas. Thats a decent amount of heat.
I think you won't get much contact area between the copper and the steel housing, so there'll be poor heat transfer/thermal exchange. Maybe 1/8 contact every 3/8, if you wrap the 3/8 copper tightly.
If you wrap the tube around as a coil, the last wrap will have less effect than the first wrap as it heat soaks.
If you really wanted to complicate it, you could make up some manifolds and run multiple lots of 3/16 tube from a manifold, around the housing, then back into a collector manifold before going to your heat exchanger.
View attachment 1482845 View attachment 1482846 View attachment 1482847 View attachment 1482848 View attachment 1482849
What's this product? The gold is a nice touch :D
Is it just a layer of foil tape? Or have you put some insulation on before taping?
Did you wrap the rest of the intake tract?
Where is your IAT sensor?
You could also try making your truck taller because the air gets colder at higher elevation.
Is that why I suck at running? cause my mouth isn't as high off the ground as others?
Anyone else suspect heat-soak of the MAF is making intake temps look higher than they actually are on snorkel'd rigs?
I now it's definitely happening on my GM MAF, to the point that I'm no longer using the in-MAF IAT, and have installed a separate one.
Edit: know. I seriously need to proofread
I also wonder this.
Remove the hood. Then the heat can get out.
Install vents in the hood or fenders.
Dry ice packed in the filter canister.
Dry ice pack the fuel lines.
Remove the right front headlight assembly and draw cold air from the front. No snorkel required.
I know you're being facetious but if you've ever wondered why Toyota doesn't make the hood scoop functional on the Tacoma its because you get worse cooling performance, at least according to an interview with Mike Sweres I saw once.
Basically it interrupts the laminar flow from grill to rad to engine bay and out. Introducing turbulent air effectively removes the vacuum you create with a fan.
Hood scoops were intended to draw outside air into the air box. Hood scoops should be completely sealed from outside-airbox as to not introduce any engine bay air (01-04 Mustang Mach 1's do this very effectively with the "shaker" style hood).
Hood vents don't channel outside air in they help draw the hot air out.
I could see how a "scoop" would interrupt the engine bay air flow...but I can only see how vents would help.
If they weren't so damn ugly, I'd have some myself.
*sorry to all you hood vent guys/gals*
I hear ya. I just can't cut into my hood. You are right about scoops and vents, just something to consider re: drastic home brew air cooling options.
Can they still open the hood? Wouldn't that hit the cowl?
Absolutely does not impede anything and lets all the AZ heat escape. I believe they are using 1.5" blocks.
The idea came after running the beaches in Mexico and SC not being able to keep things cool due to the heavy sand load. Every time we stop and opened the hood it would quickly cool down so we propped the hood a couple inches in front and no more overheating.
SC'r under the hood temp testing back in my SC days showed the hottest temps were back at the firewall.
