Thought - Water Jacketed intake
Sandy Utah area
I was just thinking about this the other day and I might even mock something up if I can find cheap parts unless you can convince me otherwise but...what about water jacketing the filter housing?
We all know Air Inlet Temp has a big effect on power and how the truck runs, most people solve it with snorks or hood vents but I was looking at the filter housing and noticing how ideal is it for water cooling.
My plan would be to wrap copper tubing around the filter housing (10 wraps? as many as I could) and then wrap that in neoprene or similar wrap to keep it tight against the housing and insulate it a little. Run a small 12v pump to a cheap and small exchanger on the front and have it either relay off something or simple in cab switch.
I figure most of the AIT issue is heat soak on the metal housing and passing over the manifolds, so If I could get the housing down to ambient or below it might help.
Thoughts?
The trick would be sizing the exchanger, but I think instead of doing it to the engineering book I would just get something cheap and easy and go from there.
EDIT: Yes I realize its just a cheap Charge Air cooler, but the housing actually has a lot of surface area and it wouldn't come with a flow penalty like a charge air system.
Yeah, I was thinking it's basically an intercooler. Do the diesel guys have something small that would fit? Not sure you're going to get fast enough heat transfer, but I'm not a thermodynamic engineer.
The other thought that came to mind was this is one more spot to spring a leak. You're not planning on tapping into the coolant system, but rather something independent? In which case you'd need a heat exchanger somewhere else to get rid of the heat picked up.
Yeah fully independent. As you transfer that's the question. Based on my experience with hydronic system I would guess 3/8th with a moderate flow should remove a measurable amount of heat
I'd say the tradeoff won't be worth it. I don't believe the air will be hanging around long enough in the air box to benefit from the external cooling of the intake box. If you were trying to squeeze an extra few HP out of a highly modified race vehicle I could see justification of similar ideas. To properly cool the air you would need a intercooler for the air to pass through...without forced induction you'll just be restricting air flow IMO.
I'd just put on a snorkel if you're worried about IAT. It doesn't have to be rocket science!
I'm not worried about cooling the air as much as I am preventing heat soak in the housing.
I think NLXTACY reported his intake air temps were within 15-20 degrees of ambient with the addition of a snorkel, way better than my IAT of 160f yesterday in 100f ambient temps. (and water temps at 211 :frown:)
If you're concerned about heat soak, perhaps try a radiant barrier on the air filter housing? I know snorkel isn't active cooling but I feel like a radiant barrier + snorkel could really help mitigate temps inside the air filter housing.
Im not interested in a snorkel. Im not into pretending I need water fording capability and the dust issue issn't really there with these housings.
Do you anticipate being able to pull a worthwile amount of heat from the filter housing? It's pretty slick inside, not to mention painted steel isn't the greatest conductor of heat.
I don't think it would be worth the effort. To lower intake temps without a snorkel you'd be better off running an air intake pipe up to the front grille. Another option would be a hood scoop but that gets you back into the same external modified look as a snorkel.
I forget offhand, but either @FirstToy or another ceramic coated his housing, and another added the NASA-type reflective jacketed insulation adhesive sheets.
I'd see how that worked for them, or for what you're talking just add the intercooler part of @djsixbillion old S/C'ed motor. His 80 was K.I.A., so he may not check here anymore, but his album should still be around.
I'd need to run the numbers, the Charts suggest that 3/8th copper pipe should be able to take about 100 W/M^2 at these temp deltas. Thats a decent amount of heat.
For me it was neither. Although I've done water fording in Mohave and extreme dust conditions here in the deserts where it helps. I did it as a cold air intake to reduce the 170-180° IATs I was seeing.
During cooler temps I'm with 5° of ambient. On really hot days I'm around 15° of ambient. For example, this is my truck right now and it's 108° outside.
(Ignore the voltage, something else is going on)
