Those with long term experience with Depo headlights
I just picked up a 100 series with Depos and one of the high beams is burnt out. I've been searching for the best H1 bulb for replacement and I haven't seen any consensus. Phillips 100w, Orsam? What is going to be brightest and last longest, and is plug and play?
Hi y'all, hopping on this thread to ask if you know where to find the DEPO corner lights for a 1990 fj80... Most of the links here are too old and I'm having trouble locating any. I found a set on bodykits.com, but they say it's for the 1991-1997s? Would the 90 be a different size/shape from the 91? If I can't find DEPO, what is another aftermarket brand that is decent? One of my corner lights is so yellowed it's almost brown 😅 and I need to replace them asap to pass inspection. Thankss!!
@alicnorr8 : what model do you have? AFAIK the front corner lamps for the models with 4 headlamps are still available.
Go to Partsouq dot com, type in the VIN of your vehicle and search for Front Clearance Lamp. If none are available
you can send Partsouq a part request, they may be able to find it. Otherwise, DEPO was making aftermarket Corner/Clearance lamps
and you may find those on Flea bay. IME the Depos are fairly good copies of the original lamps.
