So my To-Do
-Sort out my dead headlights - DONE
-Finish installing my LED Bar - mounted, have to wire
-Install Slee headlight harness
-Install new Alternator
-Install fusible links
-Plugs, wires, rotor & cap
-Change Belts
-Check knuckles & grease as needed
-Paint and install my White Knuckle Sliders when the get here
-Firm up the Battery retainer, it moves too much for me these days
-Order and install a pair of military battery clamps
-EGR removal (this one may have to wait until after)
-Sort out my winch controller
-Change Oil and Filter
-Check Diffs, change as needed
-Have AC servicedprincess: has made this a priority!)
-replace passenger side mirror
-replace hatch struts
-replace LCAs
-adjust valves and install new valve cover gasket
-replace pcv and grommet
-replace thermostat
-change waterpump-maybe
-order new air filter
Last thing after the diff is to flip my tires on the rims. I'm so not looking forward to that task. Probly gonna get some guys over to help so I don't have to do all 4 by myself.
IH8MUD on Android
I haven't done jack.
Posted from a brick.
Better get on it if you are planning on wheeling this weekend...![]()
Not wheeling. The wife had other plans.
Lame-O
Sent from another Galaxy
Hugh Heifer said:Happy wife, happy life
DSLTOY said:One of the items on my list before GSMTR is to go to Oliver Springs/Oakridge and order items needed for the Friday night cook out and some other item we need. I thought I would go to Southern's Trailfest on May 3rd & 4th. Plan on arriving early on Friday and doing my shopping then on Saturday I want to run trails 22/42/43 over to Frozen Head State Park to see if it is an easy or moderate wagon friendly trail and check the time. If it works out we will use this for one of the guided rides. I would like some one to ride it with me, not likely to find someone at Trailfest that wants to ride that easy of trail, so would one of you east TN guys want to come ride with me on Saturday May 4 ?
I feel like I need to do more. I will try to get Friday off and meet you Roger. I will drive the 100. I will call you or email you to firm it up.One of the items on my list before GSMTR is to go to Oliver Springs/Oakridge and order items needed for the Friday night cook out and some other item we need. I thought I would go to Southern's Trailfest on May 3rd & 4th. Plan on arriving early on Friday and doing my shopping then on Saturday I want to run trails 22/42/43 over to Frozen Head State Park to see if it is an easy or moderate wagon friendly trail and check the time. If it works out we will use this for one of the guided rides. I would like some one to ride it with me, not likely to find someone at Trailfest that wants to ride that easy of trail, so would one of you east TN guys want to come ride with me on Saturday May 4 ?
jason in tn said:Front coils finally showed up still have to assemble the coil overs, diffs are supposed to done tomorrow, just pick up new to me tires from Rance, and 3 days off work got my fingers crossed it all will come together.
Sent from my detachment from reality.
