- Joined
- May 15, 2005
- Threads
- 157
- Messages
- 980
1. CDan saved me about 45% vs. local stealership parts quote.
2. FAQ suggestion to drain from block plug first is a bad idea. If you do it, >150 degree hot stuff is going to shoot out of there like a fire hose - straight at your face if you're ogling the bolt through the wheel well.
3. Putting the alternator back is a major PITA.
4. Stock hose clamps are also a PITA if you're like me and couldn't find a large pair of pliers.
5. NAPA hoses - not so good.
6. Fan, clutch and shroud all come out/go in together.
7. 1/4 drive extension w/knuckle can reach between light and grille and make removing the radiator a bit easier.
8. OEM thermostat much better than aftermarket IMO.
9. KOYO radiator is >< exactly like OEM - just doesn't have the FZJ or whatever the stamp is on the top of the stocker @ 1/2 price.
9. Flush block/heater cores, reverse flush block heater cores, flush w/distilled H2O - no more green!
