- Joined
- Aug 12, 2007
- Threads
- 963
- Messages
- 19,508
Nothing says "I shouldn't be doing any wiring" like pinch splices
Will it run correctly with a hole in it?I use an exacto knife to clean the edge, and a 1/8” drill bit on a slow setting down the middle of the stopper. The whole operation usually takes less than a minute.![]()
The thicker part of the stopper is a half inch long. Drilling at slow speed thbit should catch and spin the stopper after about an 1/8”Will it run correctly with a hole in it?
That worked. Thank you!The thicker part of the stopper is a half inch long. Drilling at slow speed thbit should catch and spin the stopper after about an 1/8”
well, wood is a good insulator------
Yikes, this looks like a weld job that I would doMaybe one should find out how to pull the shift lever before hacking up the transmission cover. And, how many holes are enough for a bikini or soft top?
