Think most Okies dream of living in mountains. Did it for 10 years now back home but still love the mountains.I am, born and raised there until I left in 98. Never really turned back after I found mountains!
You're not raining on my parade @Augustiron - it's literally comments like this that I'm here for. I wire-wheeled for about 3 hours today and about 98% of the frame is in good shape, really solid. The portion with the patch, which is on the right main chassis beam is easily the worst of it. This section is also bad on the left beam in the same place. Not sure what caused this area to be hit so hard when a few inches ahead and behind are solid (or appear so). In any case I'll take it down to bare metal and assess.I hate to rain on your parade but from zooming in on a few pictures, I would absolutely strip the coating off all of that frame before spending a nickel or minute on anything else.
It may be held together by the por treatment and be Swiss cheese in places.
That large plate patch needs to go, but look just underneath it. It's not just the holes that are an issue, it's the rust thinning out all the adjacent metal to paper thin that is an equal, and not immediately visible problem.
And That section is right where the spring perch is, structurally very important to be strong and there is nothing helping the spring perch given the Swiss cheese right above it underneath the patch.
Sandblasting that frame or chemical dip is really the only way you're going to see everything, a flap wheel isn't as indiscriminate as a sandblaster at finding the holes and thin areas.
Flap wheels take down the high spots, they don't necessarily expose the low (thin) spots.
You're not kidding. Subscribe, this build thread will be full of such hilarity.You should practice on some scrap before you get too far into that frame.
Tell us about your welding setup.
As long as you never use the full specs capacity for one Alaskan moose in the troopy maybe you will be fine
Yeah, that's a good idea actually, I might do that.Rated capacity is always done with bright new clean materials in ideal conditions by pro's. +1 for backing, pre-heat will help and gas of some kind. Not a welder either.
In the pic that is #26, that patch on the left 2x6 when finished out and ground flat could be backing for a larger plate
