- Thread starter
- #1,341
Leaking brake booster?
Haven't checked that. I'll search...
I monkeyed around (I really think that is a good term for my wrenching at the moment as I'm wandering pretty aimlessly) with the throttle linkage and carb a little ago. Cranked right off the bat without any choke - thanks to the JimC rebuild. (I love that.) Idled at about 700 - I had tinkered a bit with the idle screw last time the idle was high so that is why the idle was a bit off. I reset it to 650 and all appeared good. Revved the throttle a few times and idle went back to 650. I pushed the throttle linkage around and it was pretty tight, well for a 33 year old vehicle. I pulled up on the gas pedal and it the idle didn't drop but a bit. Checked for exhaust leaks and couldn't get much to happen with the starter fluid - I sprayed it everywhere around the intake manifold, exhaust manifold, carb base, and the donut gasket below the manifolds. Only got the same sliiiight response from the 5 cylinder area. Listened with a length of hose and didn't hear any one spot that sounded much different than any other.
Then I let it warm up...
The idle crept up, I revved the motor a few times and the idle stayed high around 1000...hmm... pulled up on the gas pedal and the idle dropped to around 650 but as soon as I let go of the gas pedal the idle went back up to around 1000.
Listened with the hose and I thought I heard an exhaust leak near the 1 cylinder but starter fluid didn't have any response.
Cut off the motor and let it sit about 20 minutes. Cranked the engine (was still warm) and same thing with the high idle and play in the throttle linkage.
I mean come on - I'm pretty sure the carb is good b/c JimC has his name on it, so that leaves the throttle linkage... and the dang throttle linkage is pretty darn simple... The exhaust leak appears to be minor too.
As soon as I get some more time which will probably be Sunday or Monday I am going to check my timing and valves. Trollhole set those for me so they shouldn't be off much if at all...
Argh... I really don't want to have to drive to ATL and pay ACC to fix this but good grief, I just want the dang Piggie to run right.
At least I have solidified my position as a
banana mechanic. If I can't fix this there is no way I'll move to a
