Ah. Those 8" diffs sure are cute.
This.
8" is junk if you wanna be taken seriously. gotta go bigger or just start stacking up errybody's spare oem R&P's like i was doing... You will break again, so prepare yourself.
What other options do I have???
use your noodle. You're wheeling a modified rig... there is no limit to your options.
https://forum.ih8mud.com/hardcore-c...eries-weak-link-all-toyota-hd-front-axle.html
I did the "last" BIG upgrade on the Franken80...
Installed the 3:1 Marlin T-Case "Crawler" gears in the Franken80. I had never seen the inside of an 80's t-case, it was quite impressive and interesting. I wanted to get the gears installed before baby Sam gets here, because I dont see me having any time between then and GSMTR. The initial test drive (John's backyard), I like them and cant wait to test them out on the trail...
Thanks to the "Crew" for all the help getting the gears in...
First Pic- Before
Second Pic- After
Nick, did you know there's an offroad park just northeast of where we wheeled in Gurley? Its called Hollytree I think.
Never mind. I googled.
A442 1st gear: 2.950:1
Transfer Low: 2.49:1 (stock)
Transfer Low: 3.0:1 (new)
Axle ratio: 4.10 (stock)
Torque Conv multiplier 1.8 (estimated from the interwebs)
Old ratio: 2.95*2.49*4.1*1.8=54.21:1
New ratio: 2.95*3.0*4.1*1.8=65.31:1
...Those ratios look better than what was posted in the 80's section. This is what was posted in the 80's section, but it has the newer transmission (A343F) and doesnt have the torque converter in the mix (it was in a thread on the debate of which to do first TC gears or 5.29's). Plus you are the ALL KNOW TOYOTA PARTS GUY...
"These are the values I used (correct if wrong)
Transmission (A343F) 1st Gear: 2.804
Stock Transfer Case: 2.488
Marlin TC Gear: 3.116
Stock Diff: 4.10
Then obviously: 5.29
In stock form your crawl ratio in 1st gear would be: 28.6:1
With just the Marlin Crawler TC gears: 35.82:1
With just the 5.29 diff gears: 36.9:1
Both, 5.29 and Marlin Crawler gears: 46.22:1"
https://forum.ih8mud.com/80-series-tech/57788-wild-wheeling-pics.html
Nick, have you run across this thread yet? Some pretty sweet wheelin pics and sweet 80's of all levels and types.
And we need some updates on the gears too! Spill the beans; Inquiring minds want to know.
)The Frnaken80 joined the cool kids group because I installed my new 22 in. LED light bar...![]()
you poser, It's crooked!![]()
you have been drinking because of Comcast, I am sure everything looks crooked
