- Joined
- Sep 9, 2004
- Threads
- 187
- Messages
- 13,340
- Location
- Boise - Idaho
- Website
- www.snlandcruisers.com
- Thread starter
- #21
Things are starting to move forward with the project. I sold some things and other stuff I know will sell soon.
I got some 37"R17 ProComp tires I can buy for $200 to hold me over. I need 37" tires for when I go to fit the axles because I plan to run 37" rubber. It will really help to have 37" tires mounted up to the axles on the wheels, not only to move things around but also to be able to check everything out for clearances and so forth. I am definitely using the 17" Walker Evans beadlock wheel I have in this build.
Nothing really happening with selling the portal axles so if something doesn't happen with that real soon I am pulling them off the market and planning to use them, which means W/E 17" wheels too as they are a 8 on 6.5 which suits the axles. They also have 6" of backspacing which not only tucks the portals up in them well it will keep me as narrow as possible.
First order of business is going to be to chop the frame down 6" and weld it back together. Next up get the axles under it and at the same time configure suspension. Once that is done I will move to body mounts and fitting the FJ62 body on the chassis.
As far as suspension, I just have not made up my mind yet. I am planning on coils all around but not sure how much of the stock stuff I will use and if I will keep the radius arms in front. One of the first things I need to do is buy some used old front coils for an 80-series, that is really all I lack to slip an axle under the chassis. It is looking like I will buy as much of the suspension stuff as I can and that I will need from RuffStuff. Have used them in the past and like their products and customer service!
