The Dutch stole all 5-speed diesels! (nsfw?) HJ60 and BJ40
So I got a poser snorkel, what could be next? air lifters? :hillbilly:
The last to replace tie rod, BAM! :rimshot:
file.php
The last one had a damaged rubber, MR breakyaface helped
file.php
damaged, fixed grease zerc:
file.php
Fill before mounting and move around 5 times is in manual:
file.php
page BR-41 brakedisk 20 mm new and 19 mm replace, mine is 18 mm....
file.php
Snorkel arrived for cooler air temp and cleaner air, water crossing must be done now!, still work in progress:
file.php
Had to buy it after the landcruiser meeting in Storndorf my son wants to drive underwater, and when the package arrived I told him it is a birthday present for mommy.
So he was very exited about the gift for this mother, :princess: was not amused :censor: :cheers: o_O :pig:
file.php
The bolt to remove the original water separator basket (WD40 straw is in the bolthole beavis congulio)
file.php
The original filter bowl does not fit the snorkel =80 mm, so I sawed of the water separator bowl, just a few centimeters and then an extra tieup must be used:
file.php
So used a extra tierip and the blue mrT thingy is between the original clamp:
file.php
Template missing 4 th saw hole location but used some compass caliper to figue it out later.
file.php
Replace rear diff after 5000 km because paper seal was leaking, now replaced with cork, no more leak.
42181-60060 Paper gasket for diff/housing
42183-35010 Cork Gasket for cover/housing
strange black residue, might be because new oil, can also be lokka, no metal debris in oil, very small normal stuff:
file.php
