The Dutch stole all 5-speed diesels! (nsfw?) HJ60 and BJ40
Found this Russian vice grip in the sauna that is located in the boiler factory in Vogelsang!
file.php
Cleaned the hoses connections to prevent leaking, installed the hoses and add cooling liquid tomorrow.
file.php
New brakedisk and pads arrived but I want first to replace the front U joint (landcruiser SPIDER KIT UNIVERSAL PROPELLER SHAFT UNIVERSAL JOINT) part# 04371-36030 Stock Code 04371-36020; 04371-36021
file.php
Thanks guys! :bounce::steer: from here a lot of repair, no empty stuff :D :flamingo:
Dkyuss I came back and started the cooling liquid but it is a maintenance repair :wrench::deadhorse: :wrench:
and I am glad I did not wait for the hoses to break while traveling, seems easy to replace but takes me a long time to fix.
Here is the engine drain, seems to drain the last bit because I entered 14.3 liters of new cooling liquid (blue, to -26 degrees C)
The overflow takes exactly one liter to fill line.
file.php
Oke, maybe not so good, read a bit and it seems the cooling liquid gets worse in time (more corrosion, worse cooling)
And the liquid gets more acid below Ph7 so ordered test papers to test old and new:
80pcs of 1-14 pH Test indicator paper
file.php
And now the replacement of the front axle U-joint spider gear that turned into a big nightmare, especially because I want to go 10 march... :censor:
Time to replace the U joint (landcruiser SPIDER KIT UNIVERSAL PROPELLER SHAFT UNIVERSAL JOINT) part# 04371-36030 Stock Code 04371-36020; 04371-36021
They seem to be the same type for the front and rear axle (so 4 times the same) others mention front is different for J 60 model ? , find out?
Good picture topic and video makes it pretty easy but to much force will destroy the new part.
Saw the movies, checked the manuals and nothing prepared me for the s*** to come :bang:
The Toyota Landcruiser Owners Club :: View topic - Replacing a Propshaft Universal Joint:
file.php
Landcruiser (series 60) HJ60 3.9D diesel 1980->1990
notes: 8/1980-12/1991
U-joint dimensions (cup diameter x span): 32 x 92 - In between snap ring: 61 -
Grease nipple position: in the angle
front or rear axle - front or rear transfer case extension
Propeller shaft J60 PR_2
file.php
Lets start cleaning and removing, pressure wash before starting, I dont, I should :mad::bang:
file.php
Slam a marker pinch hole before separating, does the manual says anything about cleaning for hours? :confused:
file.php
It was a freezing night and I was crying and sobbing a bit under the car when my mum asked if I was okay :)
First shower under cooling liquid, then add some sand and stuff: landcruiser wrenching.
file.php
The brush was new so dont think it is used a lot and the brown stuff...
