The Cell Block Chronicles (PMC's 40 Project)
Awesome. Reliving my paint bomb/booth days with this.
thanks, but maybe more akin to your military days, as I was fighting more barn dust than a desert sandstorm, and i had to hold a night time vigil after the paint went down to make sure the barn cats didn’t walk all over it.
Pro Tip: Old Emblems covered in cement colored primer provide good concealment for the shanks:
Was able to sneak my driveshafts out of the yard for a little resizing and rebalancing care of Jackson Power Train:
Finished up e-brake install:
New u joints, cleaned up and installed:
And, yes, I have to put the creeper in 4 low moon rover mode to navigate the shop floor....
somebody must be in the hole. ie solitary.
Okay, this is what had happened:
I was inching my way towards the rest of the engine assembly.
I put on a new fan clutch and fan:
Then, worked on some test fits with the new radiator (I know the hose is not the right size by was just using what I had to make sure I had sufficient clearance from the fan):
You can see from this picture that I had to offset the radiator just a tad towards the passenger side (cut off welded bolts on the bottom of the cradle and then put some new bolts in):
Started working on a home-made shroud from a universal kit:
Cut, painted and installed:
Also, did some work on the tranny hump.
When doing a V8 swap, the trans and t case holes generally don't line up anymore (need to be moved closer to the engine bay).
So, I basically covered the old holes in fiberglass and then bondo and then cut new ones (basically a time lapse). Prison footwear makes another appearance:
Next:
Then gave it the final turd polish alongside some other pieces:
A consequence of the transmission being closer to the firewall is that you have to bend the gear shifter to get clearance under the heater. I did this with some heat and a vice:
At this point, I'm feeling my oats, and so i take the plunge and order a new AFI harness for the TBI computer. Also, ordered and installed a new prom chip calibrated to that harness. That along with all new sensors for each harness connection and a new distributor, etc..., the works:
At this point, I figure it's a good as time as any to find top dead on #1 cylinder in anticipation installing distributor, and then the throttle body and all that good stuff.
I put my socket on the crank nut and turned. Hmmm.. not moving. that's weird. It turned over when I had the oil pan off and I watched the crank move.
Well, it's been sitting a while, maybe I need a little more oompf. Out comes the breaker bar. Still no joy.
The consensus was that maybe the rings were just stuck. sitting a while in the jail cell..... Just squirt a little marvel mystery oil in the cylinders and let it sit.
So, I did that... and waited. for 2 weeks. Still no joy.
I decide I'm going to take it out to nolen's; get in on the lift , remove transmission and t case and make sure sure nothing is binding on the back end as I had installed the flywheel, pressure plate and clutch and it was certainly within my bag of tricks to screw that up.
While Nolen let me borrow his trailer, everyone was a bit pre-occupied with their own business to help load her up for the transport. So, I was on my own:
Related: Nolen's car hauler trailer has one of those sleeves on the tongue that you have to slide up (his requires a hammer assist) to secure it on the trailer ball. This is what it looks like close up:
And this is what it looks like from a distance when you don't get it seated well and a partially loaded trailer comes off the ball and proceeds to destroy the rear end of your truck:
At this point, I'm by myself in the middle of level 10 cluster. I'm officially having a bad day. But don't worry, it gets worse.
I shove the 40 back into the jail cell using my own super human strength and somehow disentangle the trailer from tailgate and rear bumper with the help of a hi-lift jack.
Miraculously I escaped with a few scratches and broken tail light glass (but Ford owns a patent on those with all the sensors and they are not available aftermarket and must be purchased as a complete assembly as I would come to find out $750 dollars later):
Got it transported and on the lift:
Removed my custom "Pat Rick" drive shafts and then the gears:
Removed clutch pieces and fly wheel and gave it some hard cranks from the back side:
At this point, there was nothing left to do but yank it:
Off with heads to find a cocktail of marvel mystery oil and rust. Bad deal. Rust makes one helluva of strong weld:
And, hence the ride of shame video that preceded this update. Honestly, not sure what happened,. Yes, the cell block is somewhat exposed to the elements but it's never spent a night without a roof over it's head and all the holes have been plugged. Maybe humidity and condensation killed it. Who knows, but it's definitely a boat anchor at this point.
I'm presently thinking I won't do a rebuild and will just try and buy a GM crate motor and drop it in. But like everything else on the planet right now, there is a bit of markup and scarcity going on with those.
So, yeah, in short, I'm on my 3rd year of this project and looking for my 3rd engine. A wiser man would have probably quit long ago, but I'm still planning on trying to resurrect this beast... at least for now.
**** all that. I’ve got a later model 350 TBI/4L60 out of a suburban. Bought it off a guy at the quick lube in Florence several years ago. Never did anything with it, but the guy led us to believe it was a solid runner when it was pulled.
It’s on a pallet at jrob’s office. It’s yours if you want it. Don’t give up on her yet!
