YezusLX
That’s a panty dropper sir. Nice work!
Purchased!Live on the site now!
100 Series MSS-L Spoiler System
**Like any good project, our new site is fully built but needs a shakedown run. Head over to beta.theartisangarage.com to grab your handcrafted parts.** The Modular Spoiler System - Lightweight (MSS-L) is the ultimate blend of utility and style for the back of your 100 Series...theartisangarage.com
Purchased!
Sry for the bump, does it catch air and help keep the rear window clean like the stock one? Mine never had one and one of the first things I noticed was all the crud getting kicked up from the pavement landing on the window vs my friends one who does have the factory wing. (Actually called a "Dust Protector")Now you're ready to insert and install the light in to the light pod. Be careful here so as not to let any of the nuts fall out that we've just pressed in.
First, line up the holes on the adaptor bracket to the holes in the top of the pod. Insert and snug up the 4 little screws in to the locknuts you pressed in.
It'll look like this when done:
And finally, lay the 3D printed trim bezel over the front of the light/pod, and insert the remaining 4 bolts. The bezel and nuts inside the pod will sandwich the light, keeping everything sturdy.
That's it! You're ready to install these light pods on to your MSS-L wings and wire them up. If you're running multiple lights and accessories, I highly recommend checking out the Auxbeam switchboard mounting brackets and switch panel mounting options, all available right now at The Artisan Garage. All items were designed by @LJE , and all parts produced by either he or I.
I'd like to get one but right now only if it helps with keeping the window clean by killings that low pressure area like the OEM one does.
It does help, should be at least to the same extent as the original style wing. I expect to be putting a fresh batch of these on the shelf in the next few days!
Orderd and its already shiped! yay.These are back in stock! Get 'em while they're hot.
)?Yes it does.being the lazy sob i am, does it use the same mounting config as factory (too lazy to read all 7pgs)?
Thanks for your order!! We try our very best to fulfill super fast. If I can't get an order out within 1 business day, I get all cranky.Orderd and its already shiped! yay.
